Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Proccess of my laptop is very hot even I can't put in my lap.
I bought new laptop 3-5 months ago. It is series9 made by Samsung.
and I knew my laptop is very hot even normally its temporature was 74 degree cesus. of course, it is not using status.
if I use a something, its temporature will be around 84 or 87 degree cesus.
I install it linux and then today I just see my message log and I faced mcelogs in message file.
Jan 22 16:20:53 LaptopS9 kernel: [ 4572.243216] [Hardware Error]: Machine check events logged
Jan 22 16:20:53 LaptopS9 mcelog[1146]: Hardware event. This is not a software error.
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCE 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: CPU 3 THERMAL EVENT TSC 6530f7301d0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: TIME 1327220223 Sun Jan 22 16:17:03 2012
Jan 22 16:20:53 LaptopS9 mcelog[1146]: Processor 3 heated above trip temperature. Throttling enabled.
Jan 22 16:20:53 LaptopS9 mcelog[1146]: Please check your system cooling. Performance will be impacted
Jan 22 16:20:53 LaptopS9 mcelog[1146]: STATUS 80000000880f000b MCGSTATUS 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCGCAP c07 APICID 3 SOCKETID 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: CPUID Vendor Intel Family 6 Model 42
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCE 1
Jan 22 16:20:53 LaptopS9 mcelog[1146]: CPU 1 THERMAL EVENT TSC 6530f7330cc
Jan 22 16:20:53 LaptopS9 mcelog[1146]: Processor 1 heated above trip temperature. Throttling enabled.
Jan 22 16:20:53 LaptopS9 mcelog[1146]: STATUS 880f000b MCGSTATUS 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCGCAP c07 APICID 1 SOCKETID 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCE 2
Jan 22 16:20:53 LaptopS9 mcelog[1146]: CPU 0 THERMAL EVENT TSC 6530f735300
Jan 22 16:20:53 LaptopS9 mcelog[1146]: Processor 0 heated above trip temperature. Throttling enabled.
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCGCAP c07 APICID 0 SOCKETID 0
Jan 22 16:20:53 LaptopS9 mcelog[1146]: MCE 3
Jan 22 16:20:53 LaptopS9 mcelog[1146]: CPU 1 THERMAL EVENT TSC 6530f736e38
I think this laptop is wrong design. so it has a problem.
maybe, samsung is not fixing this problem. What can I do for me and my laptop??
do you have any idea???
tell me anything.
Highlighted
1 View
Re: Proccess of my laptop is very hot even I can't put in my lap.
I would suggest installing the latest BIOS version for your laptop system, this BIOS version is to be provided by the laptop manufacturer.
Also keep in mind that laptop processors are designed to support up to 100 degrees Celsius, so as long as the processor does not reaches above this temperature, it will be OK.
Highlighted
Honored Contributor I
1 View
You may want to return to Mfg. sounds like CPU heat sink not seat right. will sooner or later burn up CPU . RMA the Laptop .
