Processors
13884 Discussions
Processeur Intel i7 10700k - Intel® Performance Maximizer
vilas
Bonjour à tous, le logiciel Maximisateur des performances Intel® marche pas avec Windows 11 maintenant, Windows demande de désactiver le noyau mémoire ?.Autre question c’est mieux de faire la partition du overclock IPM dans le disque C Windows ou sur autre disque par exemple autre SSD Disponible, des fois mon processeur monte horloge a 5.8 , 6.9 vient fou merci de votre réponse je vous remercie, bonne journée à tous.
Alberto_R_Intel
vilas, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In reference to your question, yes, the Intel® Performance Maximizer should be fully compatible with Windows* 11 as you can confirm here under "Supported Operating Systems", tab:
https://www.intel.com/content/www/us/en/support/articles/000054873/processors/processor-utilities-and-programs.html
Still, I will do further research on this matter to confirm those details and also on your other inquiry about the IPM partition. As soon as I get any updates, I will post all the information on this thread.
Albert R.
Alberto_R_Intel
Hello vilas, I just received an update on this matter.
After reviewing the case we can confirm that the Intel® Performance Maximizer is not compatible with Windows* 11.
In reference to the other question, there shouldn't be a difference if it is installed on one disk or the other; however, as advice and based on our experience, if you are not going to use the Intel® Performance Maximizer very often, then we would say it is better to have in a different disk than the C: one, to avoid spending resources that might be needed more often than the tool.
Albert R.
AndrewG_Intel
Hello vilas
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
