Is my Intel Chip bad?
Some processes have Fatal Errors like below
After copying this the whole program crashed.
[May 10 06:33] Worker starting
[May 10 06:33] Beginning a continuous torture test on your computer.
[May 10 06:33] Please read stress.txt. Choose Test/Stop to end this test.
[May 10 06:33] Test 1, 52000 Lucas-Lehmer iterations of M5705025 using FMA3 FFT length 288K, Pass1=384, Pass2=768, clm=4, 2 threads.
[May 10 06:35] FATAL ERROR: Final result was 922A259E, expected: 87610A79.
[May 10 06:35] Hardware failure detected running 288K FFT size, consult stress.txt file.
[May 10 06:35] Torture Test completed 1 tests in 1 minutes - 1 errors, 0 warnings.
[May 10 06:35] Worker stopped.
I used the Intel Processor Diagnostic Tool 64Bit 4.1.9.41.W.MP
--- IPDT64 - Revision: 4.1.9.41
--- IPDT64 - Start Time: 5/10/2024 7:17:27 AM
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPUStressW - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Pass.
IPDT64 Passed
--- IPDT64 - End Time: 5/10/2024 7:21:19 AM
PASS
I tested memory with bios memory86 and it passed.
Is there settings I should enable or disable for my motherboard?
BaseBoard Product ROG STRIX Z790-E GAMING WIFI II
OS Name Microsoft Windows 11 Pro
Version 10.0.22631 Build 22631
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer ASUS
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor Intel(R) Core(TM) i9-14900K, 3200 Mhz, 24 Core(s), 32 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1202, 4/17/2024
SMBIOS Version 3.5
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Version Rev 1.xx
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume3
Locale United States
Hardware Abstraction Layer Version = "10.0.22621.2506"
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 128 GB
Total Physical Memory 128 GB
Available Physical Memory 24.8 GB
Total Virtual Memory 154 GB
Available Virtual Memory 21.0 GB
Page File Space 26.4 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Windows Defender Application Control policy Enforced
Windows Defender Application Control user mode policy Off
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Failures at that stage in Prime 95 are normally associated with RAM issues. Have you tried running it with XMP off?
Not sure how to turn it off.
It was already off.
This may be an ASUS motherboard BIOS/memory settings issue.
As an ASUS ROG STRIX Z790-E GAMING WIFI II motherboard owner you are eligible to join the ASUS ROG STRIX forum. To sign into this forum and post to it an account with ASUS is required. Just search for ROG STRIX forum and try to sign in, this will lead to the account setup system. This forum is probably more likely to give you a specific solution to your issue than elsewhere.
