To Use Windows 11, I need to upgrade or change my Intel processor Pentium 6000, which is the procedure to do it?
Your reply is welcome,
Joesmana
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
Sorry, your processor (from 2010) cannot be upgraded to support W11.
For a system this old, your only path is to replace the system with something that has an 8th gen or later processor.
There is no processor supported by Windows 11 that can use the PGA988 socket that you have.
Processors supported by Windows 11:
