Processors
13533 Discussions
Processors
WarriorPrincess
How to unlock processors?
AlHill
What is your processor model number?  Provide full model number.
[Windows 11 is the new Vista]
WarriorPrincess
Intel Core i5-7200U CPU @ 2.50GHz        Processor speed 3100 MHz        If this is not the information needed, please inform me on how to find model number. Thank You!
AlHill
You have a locked processor.  It cannot be unlocked.  For unlocked processors, you need an X or K processor.
WarriorPrincess
Thank You. What is a good processor for replacement? What are the steps for replacement? I have an Laptop HP 15-cc0xx updated to 6O5FUJF1. Again Thank You.
WarriorPrincess
I believe the manufacture of the processor i have now is Toshiba MQ01ABD100.
WarriorPrincess
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
