Processors
16320 Discussions
Q6600 and VGA problem
Hello . my pc info is
CPU : Q6600
MB: Asus P5Q Deluxe
RAM : 2x2GB Corsair 800MHz 5C
Power : 580 with 80% efficiency
VGA : Force3D Ati 4670 HD 1GB DDR3
My problem : In games after 1 ,2 , 3 or 5 min i get this error : "Display driver atikmdag stopped responding and has successfully recovered. (event id 4101) "
After searching i found this solution : I limited cpu to 1 core (system configuration > boot > advanced option > number of processors) , then the problem solved. with 4 cores enabled again , the problem appeared again .
what does this sounds ?
Are you running win 7?
yes , I`m running win 7 now . but I tested other wins like xp , vista . they were like 7 .
