Processors
14507 Discussions
Q9300 Wierd temp reading
Good day... I would like to ask if there's something wrong with my CPU. I'm using Q9300 on an Asus P5KPL-VM motherboard. Right now I'm using Core Temp software to read the temperature of the 4 cores.
These are the temp readings
TJMax = 100C
Core 0 = 56C
Core 1 = 49C <------ ( almost 9C difference??? Which sometimes reaches 13C)
Core 2 = 57C
Core 3 = 57C
Current ambient temp is 28C
I've used different software like Hardware Monitor, Real Temp like those... all readings are the same... Core 1 is way lower than the rest. I've ask my friend to check on his computer but he's using Q6600.. All temp readins are only 1C-3C diff.
Only 1 reason that I can think of why these are my reading because Core 1 is reading the case temp (integrated heat spreader of the cpu) and the rest reads the true core temp.. Am I right? Or there's something wrong with my processor?
Thanks!
