Processors
14539 Discussions
Question about Updates - i7-9700k CPU @ 3.90GHz
MRoss28
I recently built a new computer and have tried to make sure I have updated everything correctly. I have run Intel's driver detection software to identify potential updates and no additional ones have been found; however, it looks like some components are still out of date. My processer is on driver version 10.0.17763.1 and I have seen updates for this processor, such as 25.20.100.6577. When I tried to download the update, it said my device was not compatible. I have also seen other components which are not being updated by auto detect. Am I missing something?
AlHill
From where are you seeing these other drivers? The only drivers available for this processor are these:
https://downloadcenter.intel.com/product/186604/intel-core-i7-9700k-processor-12m-cache-up-to-4-90-ghz
Do not confuse graphics update with processor updates. 6577 is a graphics update, and 17763 is the Windows 10 version/build.
Do you have an add-on graphics adapter? If so, your processor graphics are likely disabled, and you would not be able to install it.
And, you should not necessarily trust what IDSA says.
Provide more information about your system, i.e. motherboard make/model, add-on graphics, etc.
Otherwise, I think you are worrying about nothing.
Doc
MRoss28
I think you may have answered the question. It may not have worked because I have an external graphics card. It was 6577 that I was trying to download. Computer specs are below.
Intel Core i7 - 9700K 3.60 GHz 8-Core Processor
ASRock - Z390 Phantom Gaming SLI/ac ATX LGA1151 Motherboard
G.Skill Aegis 16 GB DDR-2400 Memory
Crucial - MX500 1 TB M.2-2280 SSD
EVGA GeForce RTX 2080 8 GB Black
EVGA SuperNova G1_650 W 80+ Gold Fully - Modular ATX Power Supply
AlHill
Check in your bios to see if you can use the onboard graphics OR add-on graphics OR both simultaneously.
Also, look in the Device Mangler and see what display adapters it shows.
If it shows an Intel display adapter, what version does it say it has.
Doc
