So I am trying to find the code name for my processor (building out a hardened kernel so I am stripping out all the parts I don't need and going well above and beyond the nsa hardening guidelines)...
I checked out the support page for instructions on identifying processor codename --- How to Find the Code Name for Intel® Processors . This gave instructions to search for the processor itself and look under essentials, well I did that and it isn't listed on Xeon e3-1270-v6's page .
I found another page that has a list of them by which line they're from Codename list , on this page I found that they have the code name's "Denlow" for v3 line and "Greenlow" for v5 line..
Here's the kicker... Mine appears to be v6
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 158
model name : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
stepping : 9
microcode : 0xca
cpu MHz : 816.870
cache size : 8192 KB
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb invpcid_single intel_pt ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear spec_ctrl intel_stibp flush_l1d
bogomips : 7584.00
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
order ~ # dmidecode -t system
# dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 3.0 present.
Handle 0x000C, DMI type 1, 27 bytes
System Information
Manufacturer: LENOVO
Product Name: LENOVO System x3250 M6 -[3943AC1]-
Version: 06
Serial Number: J129BPR
UUID: 324AE443-B6B0-E811-8B25-3CE1A11858C7
Wake-up Type: Power Switch
SKU Number: (none)
Family: System X
Handle 0x0025, DMI type 12, 5 bytes
System Configuration Options
Option 1: JP39 TPM Physical Presence Jumper
Handle 0x0027, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Can someone please confirm with absolute certainty what the correct codename is for this line of processors?
Nevermind, found it on the ark website.
This can be closed.
This can be closed.
dot, Thank you for posting in the Intel® Communities Support.
Perfect, excellent, we are glad to hear you found the information that you were looking for.
Any other inquiries, do not hesitate to contact us again.
Albert R.
A Contingent Worker at Intel
