Processors
14514 Discussions
Résistance thermique Intel Core i5 8400H
ydouard
Bonjour
Je dois réaliser une simulation thermique d'une carte utilisant le processeur Intel Core i5 8400H.
Je ne trouve pas les résistances thermique Rth jc ; Rth ja ; Rth jb et le Tj MAX dans les datasheet de ce processeur.
Pouvez-vous me donner ces valeurs afin de pouvoir simuler ce projet ?
Cordialement
DeividA_Intel
Hello ydouard,
Thank you for posting on the Intel communities. Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Regarding your questions, I will check the inquiry internally and as soon as I have a response I will let you know.
Deivid A.
DeividA_Intel
Hello ydouard,
Based on the research performed, I would like to inform you of the following:
1. "TJ" information can be found in the datasheet of the processor on page 103:
- See the file attached
2. For the resistor information and if the details in the datasheet are not enough, I recommend you to check the Intel® Resource & Design Center:
- Web page: https://www.intel.com/content/www/us/en/documentation-resources/developer.html#panel-top-resources|most-popular
- Account: https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Deivid A.
