Processors
14818 Discussions
Ram Compactibility
SunilKumarBehera
Can I use a 1600mhz ram ddr3 with Pentium g2010 which can have a max memory frequency 1333mhz?
n_scott_pearson
You should be able to. 1600 is its XMP speed; 1333 is its default speed. If XMP is not supported, it should simply default to using 1333.
Hope this helps,
n_scott_pearson
Hope this helps,
