So, i go to the intel xtu and i go to the memory tab, and i put the values for the 2666mhz, voltage of the ram modules and change almost every value in the ts' section, after that, i restart the computer and it's all fine, but when i turn down the pc and turn it on in the next day, the pc won't load the profiles that i save and export but the intel xtu has the same values i put before turning down. Can you tell me how to fix this and have always the 2666mhz?
What is your processor model number? If not an X or K processor, XTU is not supported.
It's i7-9700k and i can change the ram frequency, on the boot of the pc it resets for the pc but the xtu still has the values but not applied.
