I ran the processor Diagnostic tool multiple times, and each time gave me the same errors, I will post the results below. However, I'm not sure if there's anything I can do software or hardware wise, or if I just need to get a new CPU to replace this one
CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
--- IPDT64 - Revision: 4.1.4.36
--- IPDT64 - Start Time: 2020-04-19 3:17:43 AM
CPU1
Genuine Intel CPU Test
Module Version: 1.0.16.64b.W
Start Time: Sun Apr 19 03:17:43 2020
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sun Apr 19 03:17:43 2020
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.20.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Cache Test
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
CPU1
IMC Test
Module Version: 1.0.17.64b.W
Start Time: Sun Apr 19 03:17:44 2020
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 32.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Test Passed!!!
End Time: Sun Apr 19 03:17:44 2020
CPU1
Parallel_PrimeNum_i5-7 Test
Module Version: 1.0.0.9
Start Time: 2020-04-19 3:17:44 AM
Test Result - FAIL
Module Math_PrimeNum.exe Completed - Fail
End Time: 2020-04-19 3:17:44 AM
CPU1
Parallel_FP_i5-7 Test
Test Result - FAIL
Module Math_FP.exe Completed - Fail
Parallel_FP_i5-7
CPU1
Parallel_Math_i5-7 Test
Test Result - FAIL
Module AVX.exe Completed - Fail
Module FMA3.exe Completed - Fail
Parallel_Math_i5-7
CPU1
Parallel_GPUStressW_i5 Test
Start Time: 2020-04-19 3:17:45 AM
Test Result - FAIL
End Time: 2020-04-19 3:17:45 AM
CPU1
Frequency Check
Module Version: 1.0.1.64b.W
Start Time: Sun Apr 19 03:17:45 2020
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Expected Processor Frequency: 3.80
Measured Processor Frequency: 3.790944
End Time: Sun Apr 19 03:17:46 2020
Total Time: in seconds: 1
System Information
Processor Information: Family 6 Model 158 Stepping 9
Number of Physical Cores: 4
Number of Logical Cores: 4
Operating System: Microsoft Windows 10 Home 64-bit
Graphics Information: NVIDIA GeForce GTX 1060 6GB
--- IPDT64 - End Time: 2020-04-19 3:17:46 AM
--- IPDT64 - Result: Fail
TL:DR
Passes: Genuine Intel, BrandString, Cache, IMC, CPUFreq
Fails: MMXSSE, Prime Number, Floating Point, Math, GPUStressW, CPULoad
To follow up:
--- Genuine Intel Test ---
Version 1.0.16.64b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.20.64b.W
IntelR CoreTM i5-7600K CPU 3.80GHz
Brand String Module Success....
--- Cache Test ---
- Detected L1 Data Cache Size -- 32
- Detected L1 Inst Cache Size -- 32
- Detected L2 Cache Size -- 256
- Detected L3 Cache Size -- 6144
Cache Module Success
--- MMXSSE Test ---
Version 1.0.22.64b.W
..could not load DetectUtils64.dll
--- Integrated Memory Controller Test ---
Version 1.0.17.64b.W
Detected Memory Size is -- 32.00GB
--- Subtest - Memory Size Test Passed ---
Memory to be allocated 1048576 byte
Memory Allocated.
Memory Deallocated.
--- Subtest - Memory Stress Test Passed ---
--- Integrated Memory Controller Test Passed ---
Version - 1.0.0.9
Parsing Parallel_PrimeNum_i5-7.xml
Module VisParticle.exe Disabled
Running Module Math_PrimeNum.exe -s 20 -resultName Math_PrimeNum_Parallel_PrimeNum_i5-7_1_Results.txt
--- Prime Number Generation Test ---
Module VisParticle.exe Not Tested
Result - Fail
Parallel_FP_i5-7
Version - 1.0.0.9
Parsing Parallel_FP_i5-7.xml
Running Module Math_FP.exe -s 20 -resultName Math_FP_Parallel_FP_i5-7_1_Results.txt
--- Floating Point Test ---
Version 1.0.19.64b.W
Result - Fail
Parallel_Math_i5-7
Version - 1.0.0.9
Parsing Parallel_Math_i5-7.xml
Running Module Math_FP.exe -s 90 -resultName Math_FP_Parallel_Math_i5-7_1_Results.txt
Running Module AVX.exe -s 90 -resultName AVX_Parallel_Math_i5-7_1_Results.txt
Running Module Math_PrimeNum.exe -s 90 -resultName Math_PrimeNum_Parallel_Math_i5-7_1_Results.txt
Running Module FMA3.exe -s 90 -resultName FMA3_Parallel_Math_i5-7_1_Results.txt
--- AVX Test ---
Version 2.0.22.64b.W
--- FMA3 Test ---
Version 1.0.19.1.64b.W
Result - Fail
Version - 1.0.0.9
Parsing Parallel_GPUStressW_i5.xml
Running Module FMA3.exe -s 30 -resultName FMA3_Parallel_GPUStressW_i5_1_Results.txt
Module GPUStressW.exe Disabled
Running Module AVX.exe -s 30 -resultName AVX_Parallel_GPUStressW_i5_1_Results.txt
--- FMA3 Test ---
--- AVX Test ---
Module GPUStressW.exe Not Tested
Result - Fail
--- DGEMM Stress Test ---
Version 1.0.7.64b.W
--- Frequency Check ---
Version 1.0.1.64b.W
..Expected Frequency -- 3.80
..Measured frequency -- 3.79096
FrequencyCheck Passed....
Also, it can't read DetectUtils64.dll, even though it's in the same folder as the program. I'm not sure why
A 7th gen processor should not be having these issues. You likely need to replace this processor. After verifying that your warranty is still active (here: Determine if Your Product Is Still Under Warranty), you need to directly contact Intel Customer Support to initiate the RMA process (you cannot do this through the forums). Here are pages where you can lookup contact information, including local phone numbers, by geography:
- U.S. and Canada: Intel Customer Support NA
- Europe, Middle East and Africa: Intel Customer Support EMEA
- Asia-Pacific: Intel Customer Support APAC
- Latin America: Intel Customer Support LAR
You can use the online forms service or email, but I actually recommend calling them directly. The above links provide local or toll-free numbers in most countries and support most local languages. You could also use the chat service (start here: Intel Customer Support Chat), but understand that this service is offered only in English and is subject to the normal (9:00-5:00 M-F) office hours in the Pacific (UTC-8) time zone.
Hope this helps,
