I have 100+ computers running Intel Turbo Boost Max Technology 3.0.
Because of this vulnerability INTEL-SA-00243 and the discontinuation of the product by Intel I now have to remove it.
I need to automate this process via SCCM, manual uninstall will be impossible. Can you tell me a command that will silently remove this product, entirely, please.
This is a simple command line string. From a program, you would pass this string to the exec() function. Same goes for scripting.
Hope this helps,
Teabag22, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this topic, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
A Contingent Worker at Intel
Hello Teabag22, I just received an update on this matter.
For this scenario, as an option, you can always use a PowerShell script to disable the Intel
https://redmondmag.com/articles/2019/08/27/powershell-to-uninstall-an-application.aspx
If what you need is to remove the Intel
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
Albert R.
