Processors
13869 Discussions
Restarts the PC and gives an error.
VBata
Log name: System
Source: Microsoft-Windows-Kernel-Processor-Power
Date: 04.08.2009 16:54:37
Event ID: 54
Task category:(39)
Level: Error
Keyword:
User: SYSTEM
Computer: DOK
Description:
CPU power management settings 7 in group 0 are disabled due to a problem in the firmware. Check with your computer manufacturer for firmware updates.
Xml events:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
 <System>
  <Provider Name="Microsoft-Windows-Kernel-Processor-Power" Guid="{0F67E49F-FE51-4E9F-B490-6F2948CC6027}" />
  <EventID>54</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>39</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8000000000000000</Keywords>
  <TimeCreated SystemTime="2019-08-04T13:54:37.707055300 Z" />
  <EventRecordID>4098</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="252" />
  <Channel>System</Channel>
  <Computer>DOC</Computer>
  <Security UserID="S-1-5-18" />
 </System>
 <EventData>
  <Data Name="Group">0</Data>
  <Data Name="Number">7</Data>
 </EventData>
</Event>
AGate
I suggest that you place your PC in Safe Mode with Networking and check if the issue persist in the above mode as well. Safe mode starts Windows in a basic state, using a limited set of files and drivers. It can help you troubleshoot problems on your PC.
If the issue persist in the above mode, I suggest that you place your PC in Clean Boot to check if there are any conflicts in your PC that might have caused the issue. A clean boot is performed to start Windows by using a minimal set of drivers and startup programs. This helps eliminate software conflicts that occur when you install a program or an update or when you run a program in Windows
Adrian
