Processors
14510 Discussions
SA-0086 REKEY_ERROR
MJigg
When running the SA-00086 console utility part of the out put is 'Re-Key needed:' and 'REKEY_ERROR value:'
What do these indicate ?
Hello Mr.Jiggs
Thank you for contacting Intel Technical Support,
We received your inquiry and I understand that you have problems running the SA-0086 utility. Please accept our apologies for any inconvenience this may be causing. We will be more than happy looking for a solution.
What are you running the tool for?
Are you having Intel® Management Engine issue on your computer?
If you are having the Intel® Management Engine issue please let us know the model number of your computer(s)
Leonardo C.
MJigg
I am checking the vulnerability of Intel based PC's at my place of work.
On some of the result logs I'm seeing the aforementioned values ("REKEY_ERROR value" and "Re-Key needed").
I'm trying to find out what these mean.
MJigg
KenF_Intel
Hi Mr. Jiggs,
Sorry for the delay in replying.
I've escalated this to our engineering team.
Could you please confirm that you are running version 1.0.0.152 of the detection tool? If you have an older version, please download the latest version from https://downloadcenter.intel.com/download/27150 Download Intel-SA-00086 Detection Tool
It would also be helpful if you could provide a screenshot of the output.
MJigg
Confirmed.
I am using version 1.0.0.152
Thanks. I will let you know when I get a response from engineering. It would still be helpful to get a screenshot of the log file. It would also be helpful to get a screenshot of the .xml file output.
MJigg
Hi. Engineering has confirmed that this is an error in the tool. An updated tool with a fix should be available in 1-2 weeks.
Your system should be showing as Not Vulnerable.
