INTEL webcam SR 300 Depth intermittently inoperative. When uninstalled/reinstalled it works for a few hours, then stops. Drivers indicated as up to date. BIOS "updated". Error code 0xA00F4244 < "no camera attached". Sometimes shows on device manager, sometimes not.
You will get better support here:
https://support.intelrealsense.com/hc/en-us/community/topics?erpm_id=1234530_ts1600136184847
Thanks for responding.
I went through the posts you referred. Didn't find anything that helps. Device manager says camera is working properly.
No, that's not what was meant. Go to that forum and re-post your question(s) there. You will get the better mindset for these issues.
Thanks as always for tagging me, Al.
I did respond to this question on the RealSense forum but there was not a reply to my comment yet.
https://support.intelrealsense.com/hc/en-us/community/posts/360051471773/comments/360012987214
I am only seeing Marty's comment in response to the original post. I am not seeing any subsequent response (comment) from @RGAR.
Marty,
The computer is a desktop 27-ao27c, "All-In-One". Purchased in 09/2016.
R
Is the camera built into the computer or attached separately with a USB cable please?
Marty,
The desktop computer is an HP 27-a027c. Purchased in 09/16.
R
My question was if the camera is plugged into the computer with a cable or if it is built into the computer.
The camera is built into the computer. No external cables or devices. There is a small circle in the top frame of the screen with a tiny glowing green light. Norton says that the webcam is activated for Skype, Chrome, etc. each time I change sites.
Thank you very much for the confirmation that it is a built-in RealSense camera. History with such cases has shown that once the built-in cameras have problems then they are very hard to repair compared to a camera attached by a cable. If it is working intermittently then it may be better to live with the problem than spend a very long time trying to find a solution that works and likely not succeeding. I am sorry that I do not have better news.
