How to include support of PCIe Gen3 on S2600GZ?
CPU E5-2690 V1 is not able to work with PCIe Gen3 normally?
/message/529724 Similar question
Platform ID https://ark.intel.com/products/56253/Intel-Server-Board-S2600GZ S2600GZ
PCI Express Revision - 3.0
Max # of PCI Express Lanes - 48
PCIe x16 Gen 3 - 2
Connector for Intel® I/O Expansion Module x8 Gen 3 - 1
BIOS Release R02.06.E006
BIOS Version: SE5C600.86B.02.06.E006.013120181511
BMC Firmware Version: 01.28.11044
ME Firmware Version: 2.1.7.328
CPU 1,2 https://ark.intel.com/products/64596/Intel-Xeon-Processor-E5-2690-20M-Cache-2_90-GHz-8_00-GTs-Intel-... E5-2690 0 @ 2.90 GHz (Rev V0 or V1?)
Max # of PCI Express Lanes - 40
SSD DC https://ark.intel.com/products/79624/Intel-SSD-DC-P3700-Series-400GB-12-Height-PCIe-3_0-20nm-MLC P3700 400GB, 1/2 Height PCIe 3.0, 20nm, MLC
in PBA G15038-350 (RISER CARD 2U TWO X16 ONE X8)
isdct.exe show -intelssd 1
- Intel SSD DC P3700 Series PHFT652000A6400LGN -
Bootloader : 8B1B0133
DevicePath : \\\\.\\PHYSICALDRIVE1
DeviceStatus : Healthy
Firmware : 8DV101H0
FirmwareUpdateAvailable : The selected Intel SSD contains current firmware as of this tool release.
Index : 1
ModelNumber : INTEL SSDPEDMD400G4
ProductFamily : Intel SSD DC P3700 Series
PCILinkGenSpeed : 2
PCILinkWidth : 4
https://www.intel.com/content/www/us/en/support/articles/000007667/server-products.html TA_102105.pdf
Intel Technical Advisory
PCI Express 3.0 Add-in Adapter Support Issue
The BIOS option "Processor PCIe Link Speed" will not be visible if the platform employs the Intel ® Xeon ® Processor E5-26xx V1, E5-24xx V1, E5-16xx V1, or E5-46xx V1 families, and the BIOS will limit the PCIe slots speed to PCIe* 2.0 speeds unless the add-in adapters have been tested for robust operation at PCIe 3.0 speeds. Refer to the web https://www.intel.com/content/www/us/en/support/articles/000007457/server-products.html page of PCIe* Gen 3 adapter support for Intel® Server Boards S4600/S2600/S2400/S1600/S1400
PCIe Gen 3 Adapter Support for Intel® Server Board Product Families
Last Reviewed: 24-May-2018
Article ID: 000007457
The table lists PCIe Gen 3 add-in adapters supported by server platforms based on Intel® Server Boards with the Intel® S4600/S2600/S2400/S1600/S1400 Chipset.
Hi Vshtopor,
Thank you for sending us detailed information about the issue and the results of Intel tools.
I have sent you a private message with a possible workaround.
Miguel C.
Intel Customer Support
Hello, Vshtopor,
The higher revision of the riser might improve or not the bandwidth performance. According to the tested SSDs with the Intel® Server Board S2600GZ, only PCIe 2.0 is supported.
The Technical Advisory 1021-5 didn't provide an alternative riser to use. It provides only RAID card models.
For your second question, it is not possible to install directly the SSDs to the board; this configuration will damage the drives (overheating issue).
Miguel C.
Hi, Vshtopor,
I am following up your case. Please let me know if I can provide further support.
Miguel C.
Hi, Vshtopor,
I am wondering if you need anything else from our side.
Miguel C.
