Processors
13582 Discussions
Safe memory voltage for an i7-9750H CPU?
David94
Hi there,
I've been interested in upgrading my OEM memory for quite some time now, but I read an article online that stated the operating voltage of memory must be within the maximum operating voltage specifications of your chipset. Through looking at my system specs, I was able to determine that my OEM memory operates at around 1.2V . However, I've been looking at high-performance RAM that runs at 1.35V . Can this voltage increase be potentially dangerous to my system?
Thanks!
n_scott_pearson
Super User Retired Employee
Using memory that uses a higher bus frequency or a higher voltage than the processor has been validated to support is technically a form of overclocking. It is stressing the processor beyond its validated (and warranted) limits and a resulting failure could void your warranty.
David94
I appreciate your response, but that is basically a reiteration of what I first said. I'm asking if my specific processor can handle a voltage load of 1.35V as opposed to 1.2V. I already know that my system can handle a frequency up to 3200MHz, as the OEM memory is running at that frequency by default.
n_scott_pearson
No one can say whether *your* processor is going to work at this higher voltage. It likely will, but there's always a chance that it may not (it certainly isn't guaranteed to do so).
David94
I wish there was some way to easily discern the voltage capacity of certain processors. However, I seriously doubt a voltage increase of .15 would fry my board. After all, I'm looking at running my new memory its base frequency.
AlHill
@David94 Regarding undervolting your processor, you cannot do that.  It is a security risk.  As such, Intel has disabled it.
https://securityboulevard.com/2019/12/plundervolt-a-new-intel-processor-undervolting-vulnerability/
David94
No offense, but where in my post did I say that I was trying to operate my processor under its normal voltage? I'm simply trying to discern what the maximum memory operating voltage is. You know, RAM?
AlHill
"I wish there was some way to easily discern the voltage capacity of certain processors. However, I seriously doubt a voltage increase of .15 would fry my board."
Whatever...
David94
You people seem like a bunch of talking heads who don't want to help. You're sitting here assuming that I'm trying to benchmark my processor when in reality I just asked a simple question.
AlHill
You have been provided the answer, and that it is technically a form of overclocking.
You can do what you want with that information.
