Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12955 Discussions
Simple MPICH test fails
whatheway
I get the following error when I try to run this code:
Error:
mpirun ./a.out |& tee comp_test2.txt
Test 2
C function called by Fortran
Values are xx = 2.00 and ii = 1
Abort(2139535) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(176)........:
MPID_Init(1538)..............:
MPIDI_OFI_mpi_init_hook(1511):
open_fabric(2565)............:
find_provider(2683)..........: OFI fi_getinfo() failed (ofi_init.c:2683:find_provider:No data available)
# SSU Scan Information
Scan Info:
Version:"1.0.0.0"
Scan Date:"2022/12/18"
Scan Time:"14:53:03"
## Scanned Hardware
Computer:
BaseBoard Manufacturer:"Micro-Star International Co., Ltd."
Bios Mode:"UEFI"
Bios Version/Date:"H.10,11/15/2022"
CD or DVD:"Not Available"
Platform Role:"Linux will-MS-7D91 5.15.0-56-generic #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux"
Processor:"13th Gen Intel(R) Core(TM) i9-13900K"
Serial Number:"Default string"
SMBIOS Version:"3.5.0"
Sound Cards:"USB-Audio - USB Audio"
Sound Cards:"00"
Sound Cards:"USB-Audio - C270 HD WEBCAM"
Sound Cards:"00"
Sound Cards:"HDA-Intel - HDA NVidia"
Sound Cards:"HDA NVidia at 0x51080000 irq 17"
System Manufacturer:"Micro-Star International Co., Ltd."
System Model:"MS-7D91"
System Type:"x64-based PC"
- Display
- "NVIDIA Corporation GA104 [GeForce RTX 3060 Ti Lite Hash Rate] (rev a1) (prog-if 00 [VGA controller])"
Adapter RAM:"size=8G"
Adapter RAM:"size=32M"
Capabilities:"[60] Power Management version 3"
Capabilities:"[68] MSI: Enable+ Count=1/1 Maskable- 64bit+"
Capabilities:"[78] Express Legacy Endpoint, MSI 00"
Capabilities:"[b4] Vendor Specific Information: Len=14 <?>"
Capabilities:"[100] Virtual Channel"
Capabilities:"[250] Latency Tolerance Reporting"
Capabilities:"[258] L1 PM Substates"
Capabilities:"[128] Power Budgeting <?>"
Capabilities:"[420] Advanced Error Reporting"
Capabilities:"[600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>"
Capabilities:"[900] Secondary PCI Express"
Capabilities:"[bb0] Physical Resizable BAR"
Capabilities:"[c1c] Physical Layer 16.0 GT/s <?>"
Capabilities:"[d00] Lane Margining at the Receiver <?>"
Capabilities:"[e00] Data Link Feature <?>"
Caption:"NVIDIA Corporation GA104 [GeForce RTX 3060 Ti Lite Hash Rate] (rev a1) (prog-if 00 [VGA controller])"
Device ID:"GeForce RTX 3060 Ti Lite Hash Rate"
Driver:"nvidia"
Driver Path:"/lib/modules/5.15.0-56-generic/kernel/nvidia-525/nvidia.ko"
Driver Provider:""
Driver Version:""
Flags:"bus master, fast devsel, latency 0, IRQ 184"
I/O Ports:"I/O ports at 4000 [size=128]"
Manufacturer:"NVIDIA Corporation [10DE]"
Manufacturer:"Intel Corporation [8086]"
Power Management Capabilities:"Power Management version 3"
Refresh Rate - Current:"60.00 59.94 50.00 "
Refresh Rate - Current:" 2560x1440 59.95* "
Resolution:"1920x1080 59.94 50.00 "
Resolution:" 2560x1440 59.95* "
- Memory
Physical Memory (Available):"59205 MB"
Physical Memory (Installed):"64082 MB"
Physical Memory (Total):"66130 MB"
- "Controller0-DIMMA2"
Capacity:"32 GB"
Configured Clock Speed:"Not Available"
Configured Voltage:"1.35 V"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First Position"
Locator:"Controller0-DIMMA2"
Manufacturer:"G Skill Intl"
Maximum Voltage:"1.35 V"
Minimum Voltage:"1.1 V"
Part Number:"5-5600J2834F32G"
Serial Number:"00000000"
Type:"Synchronous"
- "Controller1-DIMMB2"
Capacity:"32 GB"
Form Factor:"DIMM"
Locator:"Controller1-DIMMB2"
Type:"Synchronous"
- Motherboard
Product:"MAG Z790 TOMAHAWK WIFI (MS-7D91)"
Serial Number:"07D9140_MB1E201253"
Version:"4.0"
- Networking
Interface enp3s0:"Not Available"
Interface wlo1:"Not Available"
- Operating System
Boot Device:"/dev/sdd2"
Last Reset:"up 3:27"
Locale:"en_US"
OS Manufacturer:"Ubuntu 22.04.1 LTS \n \l"
OS Name:"Ubuntu 22.04.1 LTS \n \l"
Page File:"/swapfile"
Page File Space (Available):"2097148"
Page File Space (Used):"0"
Physical Memory (Available):"59219 MB"
Version:"5.15.0-56-generic GNU/Linux"
Virtual Memory (Available):"2097148"
Virtual Memory (Total):"65620824"
- Processor
- "13th Gen Intel(R) Core(TM) i9-13900K"
Architecture:"x86_64"
Available:"Offline"
Byte Order:"Little Endian"
Cache Size:"36864 KB"
Caption:"13th Gen Intel(R) Core(TM) i9-13900K"
- Characteristics
64-bit capable
Enhanced Virtualization
Execute Protection
Hardware Thread
Multi-Core
Power/Performance Control
CPU Speed (Minimum):"3000.000"
CPU Speed (Maximum):"8500 MHz"
Current Voltage:"1.4 V"
External Clock:"100 MHz"
Family:"Core i9"
- Flags
"ACPI (ACPI supported)"
"APIC (On-chip APIC hardware supported)"
"CLFSH (CLFLUSH instruction supported)"
"CMOV (Conditional move instruction supported)"
"CX8 (CMPXCHG8 instruction supported)"
"DE (Debugging extension)"
"DS (Debug store)"
"FPU (Floating-point unit on-chip)"
"FXSR (FXSAVE and FXSTOR instructions supported)"
"HTT (Multi-threading)"
"MCA (Machine check architecture)"
"MCE (Machine check exception)"
"MMX (MMX technology supported)"
"MSR (Model specific registers)"
"MTRR (Memory type range registers)"
"PAE (Physical address extension)"
"PAT (Page attribute table)"
"PBE (Pending break enabled)"
"PGE (Page global enable)"
"PSE-36 (36-bit page size extension)"
"PSE (Page size extension)"
"SEP (Fast system call)"
"SSE2 (Streaming SIMD extensions 2)"
"SSE (Streaming SIMD extensions)"
"SS (Self-snoop)"
"TM (Thermal monitor supported)"
"TSC (Time stamp counter)"
"VME (Virtual mode extension)"
ID:"71 06 0B 00 FF FB EB BF"
Level 1 Cache:"fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req umip pku ospke waitpkg gfni vaes vpclmulqdq tme rdpid movdiri movdir64b fsrm md_clear serialize pconfig arch_lbr flush_l1d arch_capabilities
896 KiB (24 instances)"
Level 2 Cache:"32 MiB (12 instances)"
Level 3 Cache:"36 MiB (1 instance)"
Load:"load average: 0.04, 0.14, 0.15"
Manufacturer:"Intel(R) Corporation"
Model:"183"
Name:"13th Gen Intel(R) Core(TM) i9-13900K"
Number of Cores:"24"
Number of Cores - Enabled:"24"
Part Number:"To Be Filled By O.E.M."
Socket Designation:"U3E1"
Status:"Populated, Enabled"
Version:"13th Gen Intel(R) Core(TM) i9-13900K"
Voltage:"1.4 V"
Virtualization:"Not Available"
- Storage
- "WD Blue SA510 2.5 1000GB"
Capabilities:"LBA, IORDY(can be disabled)"
Capabilities:"Queue depth: 32"
Capabilities:"Standby timer values: spec'd by Standard, no device specific minimum"
Capabilities:"R/W multiple sector transfer: Max = 1 Current = 1"
Capabilities:"Advanced power management level: 254"
Capabilities:"DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 "
Capabilities:"Cycle time: min=120ns recommended=120ns"
Capabilities:"PIO: pio0 pio1 pio2 pio3 pio4 "
Capabilities:"Cycle time: no flow control=120ns IORDY flow control=120ns"
Caption:"/dev/sdd"
Cylinders - Total:"16383"
Description:"Not Available"
Firmware:"52015100"
Heads - Total:"16"
Index:"Not Available"
Interface Type:"ATA"
Manufacturer:"WD"
Model:"WD Blue SA510 2.5 1000GB"
Partitions:"Not Available"
Sectors - Per Track:"63"
Serial Number:"223402808122"
Size:"1024*1024: 953869 MBytes"
Size:"1000*1000: 1000204 MBytes (1000 GB)"
Size - Available:"Filesystem 1K-blocks Used Available Use% Mounted on"
Size - Available:"/dev/sdd2 959786032 52210092 858747732 6% /"
SMART Attributes:"* SMART error logging"
SMART Attributes:"* SMART feature set"
SMART Attributes:"* SMART self-test"
- SMART
005 Reallocated_Sector_Ct :100:"010"
009 Power_On_Hours :100:"000"
012 Power_Cycle_Count :100:"000"
165 Unknown_Attribute :100:"000"
166 Unknown_Attribute :100:"000"
167 Unknown_Attribute :100:"000"
168 Unknown_Attribute :100:"000"
169 Unknown_Attribute :100:"000"
170 Unknown_Attribute :100:"000"
171 Unknown_Attribute :100:"000"
172 Unknown_Attribute :100:"000"
173 Unknown_Attribute :100:"005"
174 Unknown_Attribute :100:"000"
184 End-to-End_Error :100:"097"
187 Reported_Uncorrect :100:"000"
188 Command_Timeout :100:"000"
194 Temperature_Celsius :100:"014"
199 UDMA_CRC_Error_Count :100:"000"
230 Unknown_SSD_Attribute :100:"000"
232 Available_Reservd_Space :100:"004"
233 Media_Wearout_Indicator :100:"000"
234 Unknown_Attribute :100:"000"
241 Total_LBAs_Written :253:"000"
242 Total_LBAs_Read :253:"000"
244 Unknown_Attribute :100:"000"
- "SD/MMC"
Capabilities:"IORDY not likely"
Capabilities:"Cannot perform double-word IO"
Capabilities:"R/W multiple sector transfer: not supported"
Capabilities:"DMA: not supported"
Capabilities:"PIO: pio0 "
Caption:"/dev/sdg"
Cylinders - Total:"0"
Firmware:"Not Available"
Heads - Total:"0"
Manufacturer:"Not Available"
Model:"Not Available"
Sectors - Per Track:"0"
Serial Number:"Not Available"
Size:"1024*1024: 0 MBytes"
Size:"1000*1000: 0 MBytes"
Size - Available:"/dev/sdg1 31154688 4100928 27053760 14% /media/will/3436-6462"
SMART Attributes:""
whatheway
So this issue was having the intel mpi program in the $PATH and $LD_LIBRARY_PATH
Once I removed the intel mpi program from the both of those places in .bashrc it fixed the issue.
Alberto_R_Intel
whatheway, Thank you for posting in the Intel® Communities Support.
Perfect, it is great to know that the issue got fixed after removing the Intel® MPI program from the both of those places in .bashrc.
Thank you very much as well for sharing the solution, we are sure it will be very useful and helpful for all the peers looking at this thread.
Any other inquiries, do not hesitate to contact us again.
Albert R.
