Regards Intel corprlation.
My name is colminzu2. Thank you your coporation.
Present for corporation we have ideas.
exsample one graphical software regster.
| [here position(x,y)] <= fx1_regsiter_AX( "32byte_data")={ return( "__asm( "*")__; ); }
| |<logical graphical buslines.
| [here position(x,y)] <= fx2_register_BX( "32byte_data")={ return("__asm("*")__; }
(y) DX CX MMX FMA or security system.
(x)----------------------------------------------------------------------
Connect to geometory points [here positioins].
into software ECC memory model or Software L1 L2 L3 software cachee and Big ZFS ARC filesystem cache( software emulation on graphic giometry emulation ).
software geometry system.
AX---- | Soft geometory core |
| and geometry logical bus |----------CX
BX-----| i386 |----------DX
Virtual geometry transform connector are can we software ecc memory model?
I'm difficult english very sorry.
Thank you very mach. I'ts a fun.
Tahnk you very mach Linus tovalds.
Thank you very mach Intel corporation.
Hello colminzu2,
The ECC memory model is related to the memory modules. To have more insight and a better understanding of your issue, provide me with a more detailed description of your Idea, and information on what you are looking for. Also, I want to confirm why it is related to the processor.
Create a report using the Intel
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
• Open the application and click on "Scan" to see the system and device information. By default, Intel
• To save your scan: click on "Next"; then "Save."
Jean O.
Hello colminzu2,
I hope you are doing fine.
Jean O.
Hello colminzu2,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
