Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Substituição de processador
boa tarde a todos, sou novo aqui, minha primeira duvida é qual o melhor e mais top processador para substituir meu PENTIUM DUAL CORE E2200 ?
Highlighted
Super User Retired Employee
What board is the processor plugged into?
Highlighted
Community Manager
Nome da Placa Mãe: MSI Q965MDO (MS-7276)
Highlighted
It is likely one of the Core 2 Quad versions, but you need to check with MSI regarding what processors are actually supported by their BIOS. In order for a processor to be used, it must be socket, board *and* BIOS compatible.
Highlighted
Community Manager
amigao desculpa a demora pra respondee, minha internet é orrivel e em dias chuvosos da muito problema;
eu esqueci de perguntar minha placa mae te esse processador de 2 nucleos ela vai aceitar um processador de 4 nucleos ?
Highlighted
It might or it might not accept a Core 2 Quad processor; I can't tell you for sure. You must contact MSI and ask them to answer this question. In order for a particular processor to be used, it must be board, socket and BIOS compatible. Since MSI controls what the board and BIOS will support, MSI must provide the answer to this question.
Highlighted
Community Manager
certo estava pensando nessehttps://produto.mercadolivre.com.br/MLB-940553602-processador-intel-core-2-quad-q6700-266ghz-8mb-775... Processador Intel Core 2 Quad Q6700 2.66ghz 8mb 775 + Brinde - R$ 124,86 em Mercado Livre POR SER BARATO tava pensando em arriscar se ele nao funcionar nao tem perigo de queimar a maquina certo ?
Highlighted
Wrong. Some motherboards did not provide the necessary power to the processor socket to support the Core 2 Quad processors (over Core 2 Duo processors) and this can result in damage to the processor or the motherboard. Don't install a processor unless you are sure it is supported. Bottom line, contact the board manufacturer for the answer to this question.
This is my last response on this subject. How you proceed is up to you -- but don't come back here crying if you ignore my advice and you end up frying something.
