Processors
16110 Discussions
TDP Max 14900KS
Alex671
Bonjour, Mon revendeur propose 2 versions du processeur Intel CORE I9-14900KS 3.20GHZ. Une avec un TDP Max de 150W et une avec un TDP MAX de 253W. Est-ce que ces 2 versions existent oùest-ce une erreur de sa part? Meilleures salutations
VonM_Intel
Hi, Alex671.
Thank you for posting in our Community.
Please be advised that this response has been translated using a web-based translation tool, which may result in some inaccuracies.
The Intel® Core™ i9-14900KS processor indeed has two specified power levels: a Processor Base Power (PBP) of 150W and a Maximum Turbo Power (MTP) of 253W. These are not two separate versions of the processor, but rather two power states that the same processor can operate under. The PBP is the base power consumption under normal operation, and the MTP is the power consumption when the processor is running at its maximum turbo frequency.
It's important to note that the processor will dynamically adjust its power consumption and performance level based on the workload and the system's cooling solution. So, it's not a mistake on the part of your reseller; they are likely just listing the two power states that the processor is designed to operate within. For more information on how to identify your processor, you may refer to this link.
Von M.
VonM_Intel
Hi, Alex671.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
