Processors
13161 Discussions
TEMPERATURA DO PROCESSADORS I5 3470
SDALMEIDA01
OLÁ, TENHO UM PROCESSADOR I5 3470 E GOSTARIA DE SABER O QUE FAZER PARA ABAIXAR A TEMPERATURA DELE, POIS JÁ  FIZ DE TUDO E A TEMPERATURA CHEGA A 105 GRAUS QUANDO RODO JOGOS.
A TEMPERATURA AMBIENTE DELE FICA ENTORNO DE 65 GRAUS, E LOGO QUE ABRO ALGUM PROGRAMA JÁ SOBE PARA 85 GRAUS, JÁ TROQUEI A PASTA TÉRMICA, JÁ VERIFIQUEI O COOLER, ETC.
JÁ NÃO SEI O QUE FAZER, ESPERO QUE TENHAM UMA SOLUÇÃO, OBG
n_scott_pearson
Super User Retired Employee
First of all, the temperature with Windows 10 idle should be below, say, 45c. If it is not, then there is something wrong with the cooler. At idle (and fan at its minimum speed), the cooler should be able to keep the temperature this low. That it is not maintaining this level is an indication of a problem.
At the other end of the spectrum, above, say, 85c, the cooler's fan should be running at 100% duty cycle (i.e., full speed). Is it? If not, you need to change the fan speed control settings in the BIOS. It could also be an indication of a problem with the cooler.
So, cooler problems, causes are:
  • TIM (paste) not properly installed (too much, too little, not applied evenly).
  • Cooler not properly mounting on the processor (even pressure across the four mount points).
  • Fan Speed Control programming in the BIOS is not effective.
  • Cooler is insufficient for the processor (not extracting wattage, not providing proper thermal mass). Get a better one.
  • Cooler is failing.
Hope this helps,
David_G_Intel
Hello SDALMEIDA01
Thank you for posting on the Intel️® communities.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped.
You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
Intel Customer Support Technician
