Processors
14539 Discussions
TURBO Boost
techsun
I am using Linux OS and I am trying to off turbo boost with this command "echo "1" | sudo tee /sys/devices/system/cpu/intel_pstate/no_turbo". But when I checked for validation from this command "grep MHz /proc/cpuinfo". It showed me different frequency. Can anyone please suggest me a command for off Turbo boost without an intervening BIOS setting.
HadiBrais
New Contributor III
By how much does the frequency vary? Note that disabling Turbo Boost only guarantees that the frequency of a core to never exceed the base core frequency, but it may become smaller depending on the frequency scaling governor and possibly also the BIOS settings.
If you disabled no_turbo and the core frequency still exceeds the base core frequency, then try to disable Turbo in the BIOS.
HadiBrais
New Contributor III
Bernard
Valued Contributor I
@techsun
Beside what Hadi wrote, you may also take into account the notion of  the "best core". If you are investigating the highest boost rate CPU-wide (per every core) of course.
-- Bernard
