Intel will tell you that anything that stays below the Maximum Junction Temperature (Tjmax, the temperature where PROCHOT is asserted and the processor protects itself by throttling performance), but I think that this is asinine guidance. My rules are that the processor, while under load, should keep its sustained temperatures below 90 (all temperatures in Celsius). Very short duration spikes up into the 90s are ok, but should not be reaching 100c (the typical Tjmax).
Now, all that said, there are other factors to take into account. Remember that some heat from the processor will bleed off into the motherboard itself and will affect components around the processor. Similarly, heat being exhausted in the air from the processor cooling system can also affect other components. You don't have to worry about the Chipset (PCH component); it can sustain temperatures similar to that of the processor, but many other components are unhappy with temperatures above 80.
Bottom line, you are going to have to find your balance between the acoustics necessary to keep your system cool and the under-load temperatures you will allow to be sustained.
Hope this helps,
There is no "i9 2900k".
Yeah, it was a late nite typo. Missed a number. i9 12900k.
Hope this helps,
Ill take it then that my temps are good.
and within 5secs the temp on the cores where up to 100celus. i stopped program at that. is the cpu bad or is the program bypassing safety protocols.
This is normal in a stress test, but only for a short while. Throttling should be preventing the temperatures from climbing higher (not that you can tell unless it thermtrips). Your cooling solution should be catching up and lowering temperatures away from Tjmax. If not, it is either inadequate, misconfigured or improperly installed.
When I first built my system, my cooler was not properly installed. I removed it and saw via the paste that the cooler was only making contact on about half of the surface.
Once installed properly, my CPU now runs at about 33c normally, 60c under load, and never spikes above 70c.
Hhmmm, and how is your acoustics?
Super quiet. I am using an NZXT Kraken Z73 360mm. I have 6 fans mounted to the radiator in a push/pull config. Noctua on the back, and my RGB fans on the front. I rarely hear the fans. Oh, and my cpu has been overclocked to 5.5ghz by the armoury crate AI overclocking
OMG, that radiator, with fans attached, must be awkward. How did you mount it?
Not awkward at all. I used a case that had all the room necessary, with plenty to spare.
