Boa noite pessoal?
Estou com um problema e gostaria da ajuda de vocês se possivel.
O meu e um Ultrabook Asus, Windows 10-Single Language, 64 bits
Processador intel i7-3517u CPU 1.90GHz, 2.40GHz com a Tecnologia Turbo Boost.
Formatei para o windows 10 e após atualizar os drivers o Turbo Boost parou de funcionar, não passa de 1.90GHz.
O driver Intel(R) Dynamic Platform and Thermal Framework Processor Participant após atualiza-lo ele bloquei não deixa o Turbo Boost funcionar.
Como posso estar resolvendo esse problema, alguém pode me ajudar por favor?
Desde de já fico agradecido.
Hello Tricolor:
Thank you for contacting the Intel® communities.
I would like to know what is the model of your Ultrabook, I was able to find different models with that processor in Asus website.
This would be to check if the device is compatible with Windows 10* and if the manufacturer of the device has release drivers for Windows 10*.
Also, I would like to know if you have contacted Asus, the Ultrabook was designed and integrated by them and the support is provided by them directly.
https://www.asus.com/support Support Center | ASUS Global
Esteban C
