Processors
13563 Discussions
Temperatura
Bernardo
Olá. Queria saber qual a temperatura ideal que o meu processador I5 9300H deveria ficar pois acho que ele está esquentando demais.
n_scott_pearson
Super User Retired Employee
If you ask Intel, they will tell you that anything less than Tjmax (~100c) is acceptable. What garbage!
I believe that a Tcontrol threshold should be established for these processors and cooling (fan speed control) solutions should adhere to the standard guidance for the Tcontrol threshold.
Here is a more-reasonable set of values:
Idle Temperatures:
Ideal: 30's (or less)
Acceptable: 40's
Concerning: 50's
Fully loaded Temperatures:
Ideal: 70's (or less)
Acceptable: 80's
Concerning: 90's
Hope this helps,
