Processors
13530 Discussions
Temperature Intel Proccessor Diagnostic Tool
AKaib
How can I enable the CPU Temperature Monitor?
LeonWaksman
  1. Stop the Intel PDT test.
  2. Click in Menu on Tools
  3. Click on Temperature Testing and check On
Leon
Edit:
Please disregard my comment above. It was valid for previous version of IPDT
Alberto_R_Intel
AKaib, Thank you for posting in the Intel® Communities Support.
The Intel® Processor Diagnostics Tool does an overall test on the unit, including a temperature test.
Please install the application and run the test, at the end select the option "File" then choose "View File Results" and you will be able to see the report of the temperatures the processor reached during the stress test.
If the processor passed the test then it should be working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Alberto R.
A Contingent Worker at Intel
LeonWaksman
Hi Alberto,
In the latest version 4.1.3.35, the Temperature Test is disabled. I can't find the option to enable it. Also there are no any temperature reading recorded in the results. Please see the attachments. In the previous version the temperature was monitored. This was the reason for the comment in my post above.IPDT.png
Leon
Alberto_R_Intel
Hi Leon and AKaib, Thank you for confirming that information.
Yes, the feature to test the temperature of the Intel® Processor was removed from the Intel® Processor Diagnostics Tool, as you can confirm in the following link, page 7:
https://downloadmirror.intel.com/19792/eng/The%20Intel%20Processor%20Diagnostic%204.1.3.35.W.MP%20for%20Windows%2064-Bit%20OS%20Release.pdf
So for this type of scenario when to review the temperature of the unit is needed, what we recommend is to download and install the Intel® Extreme Tuning Utility:
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-?product=66427
Alberto R.
