I would like to overclock my 13700kf but I cant do it and i dont know why.
The xtu is only allowe me to change the E core ratio.
I have an asus tuf b760m-plus wifi ddr5 motherboard
Hello @Daniel31
Thank you for posting on the Intel️® communities. I sincerely regret that this has happened to you. We would be more than glad to help you with your issue.
Take note that certain motherboards restrict overclocking to the RAM only, not the CPU. Z chipsets (e.g., Z490) support CPU and RAM overclocking. B chipsets (e.g., B460) allow RAM overclocking but not CPU. H chipsets (e.g., H410) generally don't support overclocking. For optimal overclocking, consider X chipsets (e.g., X570).
Please consider checking first with your motherboard manufacturer if the Overclocking features are enabled on your motherboard.
Isaac Q.
And i have another question about the motherboard. Can i undervolt the cpu or that is the same as the overclock?
Hello @Daniel31
Thank you for your response.
To obtain precise information regarding the possibility of undervolting the CPU or its equivalence to overclocking, we recommend reaching out to your motherboard manufacturer. They possess the necessary insights into their products and can provide you with an accurate response.
Additionally, it's important to note that overclocking the system, specifically adjusting voltage and frequency beyond the supported specifications of the processor, may void the warranty on your processor.
Isaac Q.
Hello Daniel31,
Were you able to check the previous post? Do you need additional help? Please let me know if you need more assistance.
Deivid A.
Hello Daniel31,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
