I add the log:
[243C:10A0][2018-12-12T23:48:17]i001: Burn v3.11.1.2318, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Windows\Temp\{799E5F33-CC78-4088-AD2D-A8E2F1A264A9}\.cr\Intel Driver and Support Assistant Installer.exe
[243C:10A0][2018-12-12T23:48:17]i000: Initializing string variable 'LaunchTarget' to value '[ProgramFilesFolder]\Intel Driver and Support Assistant\DSAServiceHelper.exe'
[243C:10A0][2018-12-12T23:48:17]i000: Initializing string variable 'LaunchArguments' to value 'installstartup'
[243C:10A0][2018-12-12T23:48:17]i009: Command Line: '"-burn.clean.room=C:\Users\Enderson\Downloads\Intel Driver and Support Assistant Installer.exe" -burn.filehandle.attached=184 -burn.filehandle.self=192'
[243C:10A0][2018-12-12T23:48:17]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Enderson\Downloads\Intel Driver and Support Assistant Installer.exe'
[243C:10A0][2018-12-12T23:48:17]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Enderson\Downloads\'
[243C:10A0][2018-12-12T23:48:18]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818.log'
[243C:10A0][2018-12-12T23:48:18]i000: Setting string variable 'WixBundleName' to value 'Intel® Driver & Support Assistant'
[243C:10A0][2018-12-12T23:48:18]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel'
[243C:03FC][2018-12-12T23:48:18]i000: Setting numeric variable 'WixStdBALanguageId' to value 1034
[243C:03FC][2018-12-12T23:48:18]i000: Setting version variable 'WixBundleFileVersion' to value '3.6.1.4'
[243C:10A0][2018-12-12T23:48:18]i100: Detect begin, 4 packages
[243C:10A0][2018-12-12T23:48:18]i000: Setting string variable 'NETFRAMEWORK45' to value '461814'
[243C:10A0][2018-12-12T23:48:18]i052: Condition 'NETFRAMEWORK45 >= 378389' evaluates to true.
[243C:10A0][2018-12-12T23:48:18]i101: Detected package: NetFx45Web, state: Present, cached: None
[243C:10A0][2018-12-12T23:48:18]i101: Detected package: IPIPInstallerX64, state: Absent, cached: None
[243C:10A0][2018-12-12T23:48:18]i101: Detected package: DCAInstaller, state: Absent, cached: None
[243C:10A0][2018-12-12T23:48:18]i101: Detected package: DriverUpdateUtilityInstaller, state: Absent, cached: None
[243C:10A0][2018-12-12T23:48:18]i199: Detect complete, result: 0x0
[243C:03FC][2018-12-12T23:48:22]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[243C:10A0][2018-12-12T23:48:22]i200: Plan begin, 4 packages, action: Install
[243C:10A0][2018-12-12T23:48:22]w321: Skipping dependency registration on package with no dependency providers: NetFx45Web
[243C:10A0][2018-12-12T23:48:22]i052: Condition 'VersionNT64' evaluates to true.
[243C:10A0][2018-12-12T23:48:22]i000: Setting string variable 'WixBundleRollbackLog_IPIPInstallerX64' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818_000_IPIPInstal...
[243C:10A0][2018-12-12T23:48:22]i000: Setting string variable 'WixBundleLog_IPIPInstallerX64' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818_000_IPIPInstal...
[243C:10A0][2018-12-12T23:48:22]i000: Setting string variable 'WixBundleLog_DCAInstaller' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818_001_DCAInstall...
[243C:10A0][2018-12-12T23:48:22]i000: Setting string variable 'WixBundleRollbackLog_DriverUpdateUtilityInstaller' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818_002_DriverUpda...
[243C:10A0][2018-12-12T23:48:22]i000: Setting string variable 'WixBundleLog_DriverUpdateUtilityInstaller' to value 'C:\Users\Enderson\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20181212234818_002_DriverUpda...
[243C:10A0][2018-12-12T23:48:22]i201: Planned package: NetFx45Web, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[243C:10A0][2018-12-12T23:48:22]i201: Planned package: IPIPInstallerX64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[243C:10A0][2018-12-12T23:48:22]i201: Planned package: DCAInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: Register
[243C:10A0][2018-12-12T23:48:22]i201: Planned package: DriverUpdateUtilityInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[243C:10A0][2018-12-12T23:48:22]i299: Plan complete, result: 0x0
[243C:10A0][2018-12-12T23:48:22]i300: Apply begin
[243C:10A0][2018-12-12T23:48:22]i010: Launching elevated engine process.
[243C:10A0][2018-12-12T23:48:23]i011: Launched elevated engine process.
[243C:10A0][2018-12-12T23:48:23]i012: Connected to elevated engine.
[14C4:1B40][2018-12-12T23:48:23]i358: Pausing automatic updates.
[14C4:1B40][2018-12-12T23:48:23]i359: Paused automatic updates.
[14C4:1B40][2018-12-12T23:48:23]i360: Creating a system restore point.
[14C4:1B40][2018-12-12T23:49:01]i361: Created a system restore point.
[14C4:1B40][2018-12-12T23:49:01]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{11a94529-f846-4bc2-bf32-98c3fc2147e2}, options: 0x7, disable resume: No
[14C4:1B40][2018-12-12T23:49:01]i000: Caching bundle from: 'C:\Windows\Temp\{A973F8D4-A8E6-45CA-BEFD-66908C2056D9}\.be\Intel Driver and Support Assistant Installer.exe' to: 'C:\ProgramData\Package Cache\{11a94529-f846-4bc2-bf32-98c3fc2147e2}\Intel Driver and Support Assistant Installer.exe'
[14C4:1B40][2018-12-12T23:49:05]i320: Registering bundle dependency provider: {11a94529-f846-4bc2-bf32-98c3fc2147e2}, version: 3.6.1.4
[14C4:1B40][2018-12-12T23:49:05]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{11a94529-f846-4bc2-bf32-98c3fc2147e2}, resume: Active, restart initiated: No, disable resume: No
[243C:26B8][2018-12-12T23:49:05]i336: Acquiring container: WixAttachedContainer, copy from: C:\Users\Enderson\Downloads\Intel Driver and Support Assistant Installer.exe
[243C:26B8][2018-12-12T23:49:05]i000: Setting string variable 'WixBundleLastUsedSource' to value 'C:\Users\Enderson\Downloads\'
[243C:1B70][2018-12-12T23:49:05]e000: Error 0x80070570: Failed to extract all files from container, erf: 1:4:0
[243C:26B8][2018-12-12T23:49:05]e000: Error 0x80070570: Failed to begin and wait for operation.
[243C:26B8][2018-12-12T23:49:05]e000: Error 0x80070570: Failed to extract payload: a2 from container: WixAttachedContainer
[243C:26B8][2018-12-12T23:49:05]e312: Failed to extract payloads from container: WixAttachedContainer to working path: C:\Windows\Temp\{A973F8D4-A8E6-45CA-BEFD-66908C2056D9}\0404EAB2951E3D3C5B2454E9E18ACC29D7E5D2F2, error: 0x80070570.
[243C:10A0][2018-12-12T23:49:05]e000: Error 0x80070570: Failed while caching, aborting execution.
[14C4:1B40][2018-12-12T23:49:05]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{11a94529-f846-4bc2-bf32-98c3fc2147e2}, resume: None, restart: None, disable resume: No
[14C4:1B40][2018-12-12T23:49:05]i330: Removed bundle dependency provider: {11a94529-f846-4bc2-bf32-98c3fc2147e2}
[14C4:1B40][2018-12-12T23:49:05]i352: Removing cached bundle: {11a94529-f846-4bc2-bf32-98c3fc2147e2}, from path: C:\ProgramData\Package Cache\{11a94529-f846-4bc2-bf32-98c3fc2147e2}\
[14C4:1B40][2018-12-12T23:49:05]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{11a94529-f846-4bc2-bf32-98c3fc2147e2}, resume: None, restart initiated: No, disable resume: No
[243C:10A0][2018-12-12T23:49:06]i399: Apply complete, result: 0x80070570, restart: None, ba requested restart: No
Hello, thank you very much for responding, actually I want to update my driver to manage the hardware acceleration, the product file of the program, is as follows PART1:
Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASRock" BIOS Mode:"Legacy" BIOS Version/Date:"American Megatrends Inc. P1.80 , 10/20/2010" CD or DVD:"HL-DT-ST DVDRAM GH22NS90 ATA Device"
Embedded Controller Version:"255.255" Platform Role:"Desktop" Processor:"Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz , GenuineIntel" Secure Boot State:"Not Available"
SMBIOS Version:"2.6"
Sound Card:"Dispositivo de High Definition Audio"
Sound Card:"NVIDIA Virtual Audio Device (Wave Extensible) (WDM)"
Sound Card:"Digital Power Station"
System Manufacturer:"To Be Filled By O.E.M."
System Model:"To Be Filled By O.E.M."
System SKU:"To Be Filled By O.E.M."
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"1.3.27.0"
- "Intel(R) HD Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,71 GB"
Bits Per Pixel:"16"
- "Caption":"Intel(R) HD Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics"
CoInstallers:"nvdispgenco6434201.dll,NvGenericCoInstall,nvdispco6434201.dll,NVDisplayCoInstall"
Color Table Entries:"65536"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"01/09/2012 08:00"
Driver Path:"C:\Windows\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"8.15.10.2622"
INF:"oem33.inf"
INF Section:"iILKD0"
Install Date:"Not Available"
Installed Drivers:"igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"11.X"
Monochrome:"No"
Number of Colors:"65536"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_0042&SUBSYS_00421849&REV_18\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"75 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics (Core i3)"
- "Memory"
Physical Memory (Available):"0,46 GB"
Physical Memory (Installed):"4 GB"
Physical Memory (Total):"3,68 GB"
- "BANK0"
Capacity:"2 GB"
Channel:"DIMM0"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"Manufacturer00"
Memory Type:"SDRAM"
Part Number:"ModulePartNumber00"
Serial Number:"SerNum00"
Status:"Not Available"
Type:"Synchronous"
- "BANK1"
Capacity:"2 GB"
Channel:"DIMM1"
Form Factor:"DIMM"
Manufacturer:"Manufacturer01"
Memory Type:"SDRAM"
Part Number:"ModulePartNumber01"
Serial Number:"SerNum01"
Type:"Synchronous"
- "Motherboard"
BIOS:"Default System BIOS, ACRSYS - 20101020"
Caption:"Placa base"
Chipset:"Not Available"
Date:"10/19/2010 08:00"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"H55M-LE"
Serial Number:"Not Available"
Status:"OK"
Version:"Not Available"
