Processors
16117 Discussions
The average and save temperature for 13700f while long 3d rendering
Tourky
Hi, i am a new intel cpu user last days i change my cpu with 13700f i want to ask for the safe and average temperature for my cpu while 3d rendering for a long hours maybe days i see very high temperature with intel and i want to be in the safe side i use Msi mpg 240k v2 cooler AIO and i limit the power at 219w and my temps are between 70c, 80c, some time hit 90c while rendering is this save for the long duration renders!?
Jean_Intel
Hello Tourky
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
We have no average temperature for this processor; however, based on the Intel Core i7-13700F Processor specifications, your processor supports a maximum temperature of 100°C. Any temperature equal to or below is considered expected.
If you are concerned about the temperatures, we suggest the following:
  • Check the thermal solution installation.
  • Check fan operation and status.
  • Check air ventilation.
  • Update the BIOS / Load the BIOS to deffaults values
For further information, we recommend you check the article Overheating Symptoms and Troubleshooting for Intel® Boxed Processors.
Jean O.
Tourky
80c s some picks to 90c is ok for long duration 3d rendering!?
Jean_Intel
Hello Tourky
Jean O.
Jean_Intel
Hello Tourky,
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need additional information, please submit a new question since this thread will no longer be monitored.
Jean O.
