Processors
13562 Discussions
The driver for my Intel processor uninstalls itself
flakdau
Hello, I recently bought my first laptop from ACER and decided to download my drivers. I still got no problem with the installation and everything works. However the next day a kind of screen glitch appeared on my screen and I saw on the Intel driver support assistant the Intel UHD Graphics driver needs to be installed. I thought this was just a new version of the driver I had to download but this happened two or three times since then.
I don't know if this is just a very often updated driver by Intel, but I'm a little worried about this, I don't want to reinstall it every two days.
Thank you.
AlHill
If the laptop is failing with the Acer supplied drivers, it is Acer's problem.   You need to have Acer correct this.
Also, your support and warranty are from Acer;
AlHill
For your acer laptop, you should be using the graphics driver provided by acer and not the intel driver.
flakdau
Ok thank you for your answer, is it still possible and if it is, how do I do that?
megan3000
Valued Contributor I
To do what? install the driver from Acer? or did you mean how to install (force) the driver from intel?
flakdau
Ok so I'm gonna just explain my problem from the beginning. When I received my laptop, I decided to install the drivers from Nvidia and Intel assistants and the only problem I had at this moment was I thought my Intel driver was uninstalling itself. Then I contacted ACER and posted a question on this forum to know if it was a better idea to install drivers from ACER. Both told me yes, so I did it. The problem is I had multiple BSoD during GPU tests and less performance on games. So I have no idea what I'm supposed to do?
If needed, here is a part of one of minidump files from BSoDs I previously had:
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffba06b140c060, Physical Device Object of the stack
Arg3: fffffe8f29e7f6d0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffba06b7f7d7a0, The blocked IRP
Btw I have no idea what IRP means..
AlHill
