Use Python revision 3.6.5 and GEN5 VRTT revision v1.10.1. In Fast V-Mode Test Validation, run Vmin Violation_VID2 test with reference to (#622198) document.
When FVM_VID2 is 1.5V and Offset_VID2 is 0x27h, The test results show that when the Set Frequency is 1 kHz, the VMAX is 1.702V and the VMIN is only -0.001V. For other Frequency, VMAX is only about 1V, VMIN is only about 0.8V. The values of VMAX and VMIN do not seem reasonable. Under this test condition, when only Offset_VID2 is changed to 0x00h, VMAX is about 1.5V and VMIN is about 1.3V. There seems to be something wrong with the Offset setting.
Have you encountered similar problems before and how to solve them? Please help answer this question, thank you!
Hello Alice_,
For us to further check this, please help provide the following details:
- What is the Intel product that you are inquiring?
- Can you tell us further on what is the purpose of this test?
- Can you tell us why do you need this information?
Michael L.
Hello Alice_,
Michael L.
Hi Mike:
Thank you for your reply. The problem has been resolved. The problem was affected by the equipment. At present, the test has been successfully completed.
VRTT is an official voltage regulation test tool required by INTEL(as a RD) . The following files can be downloaded from INTEL's website. May I ask where RD should ask if it encounters problems in test verification?
Alice
Hello Alice_,
Thank you for the update.
I am glad that the issue is now fixed. Since there is no more problem, I need to close this inquiry.
Michael L.
