Hi, I am in the process of designing a thermal solution for an application using the i7-7567U processor. I am looking for documentation listing the thermal resistance (junction to case, junction to ambient (no heat sink) of the Core i7-7567U. I was only able to find documentation assuming a heat pipe in use which may not be the case for my application.
Thank you,
Anthony C
Hello ACama4,
Thank you for posting on the Intel ® communities.
In order to get the information you require and for assistance with your development you will need to check in our Resource & Design center as well as our Intel ® Developer's Zone. You can find the links below:
https://software.intel.com/en-us/forum
https://www.intel.com/content/www/us/en/design/resource-design-center.html
David V
Under Contract to Intel Corporation
