Processors
16276 Discussions
Thermtrip# signal temperature for 3570k?
ssote
New Contributor II
Thermtrip# signal temperature for 3570k? I can't find out what the Thermtrip temperature is for 3570k?
Hello wingman99,
Thank you for contacting the Intel community.
Thermal trip: the processor protects itself from catastrophic overheating by use of an Intel® thermal sensor. This sensor is set well above the normal operating temperature to ensure that there are no false trips. The processor will stop all execution when the junction temperature exceeds approximately 130°C.
This is signaled to the system by the THERMTRIP# signal.
You can check more information about your processor here:
http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz
Also, you can check the https://www.intel.com/content/www/us/en/processors/core/3rd-gen-core-desktop-vol-1-datasheet.html Datasheet for more detailed information.
Ivan U.
ssote
New Contributor II
Thank you for the information.
You are more than welcome!
Ivan U.
