I’m trying to order an OEM tray i3-12300 CM8071504650906 for an ITX desktop build. A reseller has an “I3-12300 Desktop Proc 4 4p+0e Chip - Cores Up To 4.4 Ghz Turbo Tray” CM8071504650906S in stock as of next week. I can’t find the specs for the “S” version. Can someone explain the differences between the two? I will be using the system for business use only, no gaming or overclocking.
Thank You
I agree that it cannot be seen on ARK. I even tried looking using search string "i3-12300s".
Just as a side note, you do realize that you do not have any warranty from Intel when purchasing a gray market OEM tray processor, right? When you purchase a PC, it is the OEM that is providing you with a warranty for the included processor, not Intel (though Intel does separately provide a warranty to (only) the OEM).
Hello @alex1040
Please allow us to review this further and we will be posting back in the thread as soon as more details are available.
Andrew G.
Hi Andrew,
Thanks for the involvement; waiting for your response.
Hello alex1040
Thank you for your patience in this matter.
After reviewing this further, we would like to inform you that "CM8071504650906S" is not a different Product Code however it corresponds to the same product Intel® Core™ i3-12300 Processor, therefore if you use it, you will receive the same product with the same specifications.
We hope this clarifies your concerns.
Andrew G.
Hello alex1040
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
It has been a pleasure to assist you.
Andrew G.
