Processors
13563 Discussions
Trouble installing IntelvPro Powershell module
MrAvocado
Trying to install the IntelvPro powershell module from the SDK. I am adding the path to the functions and PSM1 file into the PSModulePath within the environment variable. I see the functions listed in the command window, however when I attempt to "shot details"  I get this error:
errorerror
I have tried on both Microsoft Window's Server 2012 and 2016, using both 32bit and 64bit ISE.
AMT SDK Ver: 14.2.1
JoseH_Intel
Hello RBCEmployee,
Thank you for joining the Intel community
Please allow me some time to research on your issue. I will get back to you as soon as I have relevant information
Jose A.
Intel Customer Support
MichaelA_Intel
@MrAvocado
The issue you are seeing, we have encountered. What we've seen are the following:
  1. If you log out and log back in, or restart your system, the issue should be resolved.
  2. If you have not logged off or restarted the system, if you run powershell as a user as opposed to an administrator, it should work until you log off or restart your system.
Let me know if neither of these resolve the issue.
Michael
MichaelA_Intel
RBCEmployee,
Just following up on your case as I have not heard back from you. Are you still having the error?
Michael
