Hi I have an MSI GV628RE laptop with a core I7-8750H proccessor from what i can read on here it should have the Turbo Boost Max Technology 3.0
download is there anyway i can check if it is installed and running and if it is not how do i make it run or download
Dave
Intel Turbo Boost Max 3.0 is a feature of the Intel® Core™ i7-69xx/68xx Extreme Edition desktop processor family (i.e. the i7-6800K, i7-6850K, i7-6900K and i7-6950X). You most definitely do not have it in your (heck, in any) laptop.
thanks but the intel site said it was on the I7-8750H chip set
No it didn't. I am sure you've read it wrong. Show me where it says this.
Hi as usuall cannot find it again it was in a list that was meant to be compatable with Turbo Boost Max Technology 3.0 now check somewhere else and that says it is compatable with Turbo Boost Max Technology 2.0
Scroll down to Advanced Technologies
Does that sound right
Cheers
Dave
Hello DRain2
We would like to jump in to help and clarify that the information provided by n.scott.pearson is correct.
Intel® Core™ i7-8750H Processor does not support Intel® Turbo Boost Max Technology 3.0. Only Intel® Turbo Boost Technology 2.0 is supported as per Intel's Technical Specifications:
https://ark.intel.com/content/www/us/en/ark/products/134906/intel-core-i7-8750h-processor-9m-cache-up-to-4-10-ghz.html
Also, the Intel® Core™ Processors supporting Intel® Turbo Boost Max 3.0 Technology can be found in the following link, which does not list the Intel® Core™ i7-8750H Processor:
https://www.intel.com/content/www/us/en/support/articles/000021587/processors.html
Also, we do not comment or endorse information published on third-party websites nor the information provided by your laptop manufacturer (OEM). For additional details regarding the technical specifications of your laptop, we recommend you to contact your OEM (MSI* support team).
Andrew G.
