Hi. I have a proplem. I have a laptope Asus G46VW. When it's running on battery Turbo Boost works, but when it is running from electric power supply Turbo Boost doesn't work. When i use
Turbo Boost Technology Monitor it writes "poweer saving". And everything is ok when laptope is running on battery. In both variant of electricity supply i used such power sheme as Power4gear high performance. Sorry of my English but i wish you will understand me.
Let me help you with that.
Intel® Turbo Boost Technology automatically allows processor cores to run faster than the rated operating frequency if they're operating below power, current, and temperature specification limits.
Intel Turbo Boost Technology is activated when the Operating System (OS) requests a frequency higher than the rated frequency of the processor. Whether the processor enters into and the amount of time the processor spends in the Intel Turbo Boost Technology state depends on the workload and operating environment.
Maximum turbo frequency indicates the highest possible frequency achievable when conditions allow the processor to enter turbo mode. Intel Turbo Boost Technology frequency varies depending on workload, hardware, software and overall system configuration.
Due to varying power characteristics, some parts with Intel Turbo Boost Technology may not achieve maximum turbo frequencies when running heavy workloads and using multiple cores concurrently.
Availability and frequency upside of Intel Turbo Boost Technology state depends upon a number of factors including, but not limited to the following:
Type of workload
Number of active cores
Estimated current consumption
Estimated power consumption
Processor temperature
When the processor is operating below these limits and the user's workload demands additional performance, the processor frequency will dynamically increase until the upper limit of frequency is reached. Intel Turbo Boost Technology has multiple algorithms operating in parallel to manage current, power, and temperature to maximize frequency and energy efficiency. Note: Intel Turbo Boost Technology allows the processor to operate at a power level that is higher than its TDP configuration and data sheet specified power for short durations to maximize performance.
Here you can check a table that shows how Intel® Turbo Boost works:
http://www.intel.com/support/processors/corei5/sb/CS-032278.htm http://www.intel.com/support/processors/corei5/sb/CS-032278.htm
You can also run the Intel® Processor Diagnostic Tool to test the internal components of the processor. Here you can download it:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792
I did test with Intel® Processor Diagnostic and there is a result:
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 05/07/2014 21:43:55---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 53 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-3630QM 2.40GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 2.40
Detected CPU Frequency is --> 1.20049
CPU Frequency Test Failed!!!
--- Test End Time: 05/07/2014 21:44:09---
System Information
Processor Name: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
Processor Information: Intel64 Family 6 Model 58 Stepping 9
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 16 GB
Operating System: Майкрософт Windows 8 для одного языка 64-разрядная
Graphics Information: NVIDIA GeForce GTX 660M
System Product: G46VW
System BIOS: G46VW.210
FAIL
Well it is too bad to see it failed. Here we have a couple of more steps to do due to this situation.
I would like you to try with the latest BIOS update and if you already have it try to reinstall it on your system. It is a long shoot but the system may have lost the microcode for the processor and may be causing conflicts with it (not very common at all but possible).
In case the issue persist, I recommend you contacting Asus for them to replace the processor.
