Community
cancel
Showing results for
Search instead for
Did you mean:
ORehm
Turbo boost for intet i5-3230M 2.6GHz
Jump to solution
I was using the turbo boost technology and it was giving me upto 3.2GHz, in windows 7 now i've switched to windows 10 and i can get it to work. The Turbo Boost settings are enabled in the bios. but when i try to install turbo boost drivers this happens.
I also tried
but nothing seems to work.
Please Help !!
Community Manager
Hello Obaid_Obi_,
I understand that you are having problems with Intel ® Turbo Boost Technology. I apologize for any inconvenience.
In regards to this issue, the problem is that you are trying to install the drivers for "Intel ® Turbo Boost Max", which is Intel ® Turbo Boost Technology 3.0. Your unit only supports Intel ® Turbo Boost 2.0 which works automatically as long as it is enabled in the BIOS. The Turbo Boost does not need drivers as it is enabled in the BIOS and it boosts the speed automatically depending on the tasks.
David V
AlHill
Are you 32-bit or 64-bit? If 32-bit, your ivy bridge processor is not supported on Windows 10:
https://ark.intel.com/products/72164/Intel-Core-i5-3230M-Processor-3M-Cache-up-to-3_20-GHz-rPGA Intel® Core™ i5-3230M Processor (3M Cache, up to 3.20 GHz) rPGA Product Specifications
https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html Does My Intel® Processor Support Microsoft Windows® 10?
Doc
ORehm
AlHill
Ok, thanks for the clarification. The Intel support staff will now be able to help you.
Doc
Community Manager
Hello Obaid_Obi_,
David V
