Processors
13580 Discussions
Turbo boost i7 10510 u
mateus078
Boa noite não consigo ativar a opção de turbo boost alguem pode me ajuda ? eu ja ativei na bios mias não funcionou
megan3000
Valued Contributor I
What do you mean by "it did not work"?
If you have already enabled the feature on the BIOS, then it is enabled and ready to be used... Whether it is active (getting higher clock speeds) or not depends on the working conditions and on other factors like the thermal headroom available...
The feature will be active dynamically under demand...
mateus078
Boa noite então ja tentei estressar a cpu no máximo mais não passa de 1.8
é um i7 10510 U
megan3000
Yeah, 1.8GHz is the base frequency...
How did you stress the CPU? can you post screenshots from it?
And maybe a picture from the BIOS where turbo boost is enabled?
quick question: did you try changing power or performance settings in the BIOS (if there is any available) or in windows?
mateus078
Boa noite amigo eu tinha até desistido ja ai tive que formatar meu Windows ai fui jogar gta e ele estava funcionando agora bate 4.8
