Processors
13840 Discussions
Upgrade CPU HP G4-2160br
ivan_ext
I would like to replace the current i5-3210M CPU with an i7-3612QM from an HP Pavilion G4-2160br notebook. But I have doubts about the socket.
According to the maintenance manual available at http://h10032.www1.hp.com/ctg/Manual/c03345638 the i7-3612QM CPU is compatible with the model in question.
But I would like confirmation, as I have little experience in the matter.
Comparison between the i5-3210M and i7-3612QM> https://ark.intel.com/content/www/br/en/ark/compare.html?productIds=67355,64901
AlHill
Yes, SR9MQ (the spec code) is found under "ordering and compliance, retired and discontinued" on this link:
https://ark.intel.com/content/www/us/en/ark/products/67356/intel-core-i7-3612qm-processor-6m-cache-up-to-3-10-ghz-rpga.html
This is a socketed processor and is NOT soldered to your motherboard.
AlHill
Before you do anything, you need to ask HP what processors are supported BY THEIR BIOS.   Then, you can select from those processors.
And, no, you cannot use the QM.  Not only is the socket different, it is soldered to the motherboard.
ivan_ext
Thank you for your help!
A member of the HP community reports that, according to the official notebook manual, (http://h10032.www1.hp.com/ctg/Manual/c03345638) the i7-3612QM is compatible with the notebook model in question.
Is it possible to identify an i7-3612QM using the number printed on the CPU?
https://ae01.alicdn.com/kf/HTB1IfzbeMb.PuJjSZFpq6zuFpXaD/Original-intel-core-I7-3612QM-sr0mq-processador-cpu-i7-3612qm-2-1-ghz-3-1-ghz.jpg_Q90.jpg_.webp
AlHill
AndrewG_Intel
Hello @ivan_ext
We hope that the information provided by the community has been helpful to clarify your concern. Since the thread has been marked as "Solved" we will proceed to close this inquiry now from our end. Communications with community peers may continue, but if you need any additional information from Intel, please submit a new question as this thread will no longer being monitored.
Andrew G.
