Processors
16335 Discussions
Upgrade modernization of Core 2 Duo P7350
AKo
Hello. I need your help in updating my laptop Samsung NP-R560-ASS2 with Core 2 Duo P7350 2000 3072 1066 25
Please don't send me to Samsung support. Samsung doesn't produce laptops anymore and they will not help me.
Intel(R) Processor Identification Utility
Version: 4.20.20090811
Time Stamp: 2015/12/20 06:30:15
Operating System: 6.0-6002-Service Pack 2
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 2
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
Type: 0
Family: 6
Model: 17
Stepping: 6
Revision: 60C
Maximum CPUID Level: A
L1 Instruction Cache: 2 x 32 KБ
L1 Data Cache: 2 x 32 KБ
L2 Cache: 3 MБ
Packaging: µFCPGA/µFCBGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Enhanced Halt State: No
Execute Disable Bit: No
Intel(R) Hyper-Threading Technology: No
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: No
Expected Processor Frequency: 2.0 ГГц
Reported Processor Frequency: 2.0 ГГц
Expected System Bus Frequency: 1066 МГц
Reported System Bus Frequency: 1066 МГц
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Mobile Core 2 Duo P7350
Codename Penryn
Specification Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
Package (platform ID) Socket P (478) (0x7)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping M0
Technology 45 nm
Core Speed 1995.0 MHz
Multiplier x Bus Speed 7.5 x 266.0 MHz
Rated Bus speed 1064.0 MHz
Stock frequency 2000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 3072 KBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.5x
Max VID 1.138 V
Temperature 0 62°C (143°F) [0x26] (Core # 0)
Chipset
Northbridge Intel PM45 rev. 07
Southbridge Intel 82801IM (ICH9-M) rev. 03
Graphic Interface PCI-Express
PCI-E Link Width x1
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 2 GBytes
Channels Dual, (Symmetric)
Memory Frequency 532.0 MHz (1:2)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Host Bridge 0x2A40
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 4096
BIOS Properties:Vendor Phoenix Technologies Ltd.Version 09LA.7027.20081209.JJCRelease Date 12/09/2008Size 2048 KB<td style="font-style: normal; font-weight: normal; font-size: 12.8px; font-family: verdan...
AKo
1) Can I change P7350 to P9700?
2) Where to buy original processor? If it's not possible as of end of the processor production, where to look for reliable "not original" producers? (because there are some in China)
3) Can I change P7350 to one of modern processor?
4) How to check compatibility of processor and BIOS? For example, my BIOS manufacturer is Phoenix Technologies Ltd.
AJana1
Valued Contributor I
Hello Aladdin,
Through the dumped information, I found the stepping of your processor is M0, in other words, it sits on the socket PGA-478, most likely replaceable. The Core 2 Duo P9700 might be out of the power range of your computer supports. So it might be not able to replace with that processor! Trying it might be dangerous! BIOS is always blind to the processors which could put their power consumptions into the supported range, so I just only suggest you replace your processor with Core 2 Duo P7 series. That might be safest, but everything is AT YOUR OWN RISK!
All those processors are at the phase of end-of-support, so you could only choose the used ones.
Aaron Janagewen
AKo
Dear Janagewen, thank you for help. Where I can look for power support range for processors in BIOS?!
AJana1
Hello Aladdin,
I say Power Support Range, I mean the range of voltage, current and TDP of supported processors for your notebook computer. This information has to be obtained from the Samsung. Even though it is dangerous, and might damage both of your notebook computer and processor itself, trying is another way to get this information. The TDP of http://ark.intel.com/products/36750 P7350 is 25W and voltage range is 1.062V ~ 1.150V; while http://ark.intel.com/products/42599 P9700 has a TDP of 28W, and its voltage range is 1.012V ~ 1.175V. Those minor differences might harm both of them or not at all, nobody knows before contacting Samsung or trying by yourself. But something I could make sure that the situation of burning an old processor on a Socket 370 (Tualatin) mobo rarely happened to current Intel products. But after all, it is the everything AT YOUR OWN RISK!
Aaron Janagewen
AKo
Janagewen, could that info be get from any progs like Everest, CPU-Z and similar? I mean for example some prog could get this from motherboard, could it?
AJana1
Hello Aladdin,
As far as I know it is impossible to get it from any software, it is always set by the manufacturerers, and controlled by some a specific chip. Nothing ventured, nothing gained! Why not just choose the processor you love, and just test it at the vendor and get a direct result? But again, everything is at your own risk! Anyway, I wish you good luck!
Aaron Janagewen
