Processors
16485 Discussions
Voltages, Wattages and Temperatures 13 and 14 generation.
AMR41
Seeing the amount of parameters that can be varied through the application for windows "Extreme Tuning Utility (XTU)" and how dangerous they can be for those who are not knowledgeable.
Intel can not make another application with four buttons (and whatever it has to do of other hidden settings) that allows to act on the Bios to have four modes of execution of the processor power.
Something like Windows “Processor Performance Enhancement Mode”, but better distributed?
A-Low performance: Vcore < 1.0 CPU Package Power <85 W Temperature <40ºC
B-Good performance: Vcore < 1.2 CPU Package Power <120 W Temperature <60ºC
C-Excellent performance: Vcore < 1.3 CPU Package Power <180 W Temperature <80ºC
D-Great performance: Vcore < 1.4 CPU Package Power <300 W Temperature <90ºC
I know that the digits in the example are not valid, but I think you get the idea.
JedG_Intel
Hello AMR41,
Thank you for posting at Intel Community Forum.
For me to better assist you with your inquiry, I will coordinate this with our Engineering team for checking and consideration.
We will be in touch as soon as we have an update.
Have a good one and stay safe!
Jed G.
JedG_Intel
Hi AMR41,
We thank you for your suggestion and I have received an update from our team. I'd like you to know that your suggestion has been passed on to the appropriate team already.
If you have other concerns aside from this, let me know so we could address it.
Jed G.
AMR41
Thank you  Jed G.
I am glad for the consideration.
I recently read the idea of Exodus 1337 that you exposed here  https://community.intel.com/t5/Processors/Request-XTU-New-Feature/mp/1628684/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufE0wT0tDT1RYMldMSVdPfDE2Mjg2ODR8U1VCU0NSSVBUSU9OU3xoSw#M77314
And it seems to me much better and perhaps simpler to implement than mine. I hope you will take it into account.
Best regards.
JedG_Intel
Hi AMR41,
Thank you for taking up the time to share a different community thread. We also appreciate your feedback towards the betterment of Extreme Tuning Utility tool.
Rest assured that your suggestions have been forwarded to the team handling this and in case that you have other suggestions, feedbacks, or questions let me know so I can help you with it.
Thank you for choosing Intel and have a good one!
Jed G.
JedG_Intel
Hello AMR41,
I wanted to check if you still have other questions or concerns so we can determine the best course of action.
Jed G.
AMR41
Yes Jed G.
The question is:
What are you doing to solve the problem “ Voltages, Powers and Temperatures 13 and 14 generation”?
In short, are you going to do something, yes or no?
Today is September 13, 2024
Greetings
JedG_Intel
Hello AMR41,
To further address your concern, I'd like you to know that our Engineering team are continuously conducting analysis to address the issue. Right now, as initial step to mitigate the issue, we released a microcode update which will primarily improve operating conditions for K/KF/KS processors.
Additionally, the microcode update (0x129) will limit voltage requests above 1.55V as a preventative mitigation for processors not experiencing instability symptoms.
You may also check out this link for more information.
Let me know if you need further assistance
Jed G.
AMR41
At this time it doesn't look like Intel and their engineers are doing anything, Jed.
The microcode update (0x129) came out as early as the beginning of August. And since last August 7 Gigabyte has released the FJh update for my Z790 Aorus Elite AX (rev.1.x) board driving an i7-14700K.
It's a beta update, which I think is fine for those who use the pc for gaming. Those of us who bought it for work, can't depend on a beta.
I don't know if the fault is Intel's or Gigabyte's, but the result is the same. a disaster!
Today is September 18, 2024.
And to be able to use the pc safely and without voltage problems (VID or Vcore) , temperature and Core Clocks I have to use the pc with the “Processor Performance Enhancement” on Disable, inside the Advanced Power Settings of W11.
With what I get that no problems appear (as I see in HWinfo64) and at the same time I see that I am working with +/- an i5 of ninth or tenth generation, when I have paid an i7-14700K.
Is this normal?
Regards.
JedG_Intel
Hi AMR41,
I understand the situation that you are in and I would like to make a recommendation for you to try. Could you please try to reset the settings to "Intel default settings"? If the same issue persists, let me know so I can assist you further with this.
Additionally, it seems that this inquiry is the same as this thread. Please let me know if we shall focus on that thread instead.
I look forward to your response!
Jed G.
AMR41
Good morning JedG
We can focus on the thread you want.
The issue is that Gigabyte has not yet released a Bios update that is normal, not Beta.
And you know I'm not going to install a Beta update.
That's for technicians and pc enthusiasts, not for those of us who use it for work.
Could you tell me what you mean when you say:
“Could you please try to reset the settings to “Intel default settings””.
The Z790 AORUS ELITE AX (rev.1,x) https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-1x#kf has the December 25, 2023 FH bios update installed which was when I bought the pc and no settings have been touched.
Greetings.
JedG_Intel
Hi AMR41
Since you already have a similar concern on this thread, please avoid asking the same question to avoid confusion with the information. If you have other questions regarding this issue, you may refer to the other thread for further assistance.
Furthermore, you may follow this link to implement the Intel Default Settings as we highly recommend using these. In case you have are having difficulties changing the values, please contact your board manufacturer as they might have a different term for those settings.
I hope this information helps you.
Jed G.
AMR41
Dear JedG,
To avoid any confusion, I would like to reiterate that I am not interested in upgrading to a beta version of the software. Furthermore, I am not seeking a recommendation. I have purchased an I7-14700K processor and am looking for a solution that meets the specifications of this particular model.
When can we expect Intel to deliver on their commitment?
If you don't have an answer, don't answer.
Kind regards,
JedG_Intel
Hi AMR41,
I understand that you don't want to update your BIOS to a beta version. If that's the case, a new microcode 0x12B will be released. This BIOS update has been distributed to system and motherboard manufacturers to incorporate into their BIOS. We are working with our partners to rollout the BIOS update as soon as possible.
For more information about the ongoing investigation, please visit this link
Thank you so much!
Jed G.
AMR41
Thank JedG.
I saw Thomas_Hannaford's announcement on the 25th.
I asked him if he knew how many weeks before Gigabyte publishes and I also asked Gigabyte. And I haven't had any answers.
I'm still waiting.
If you know something, please let me know.
And I just saw that Gigabyte upgraded the FJh beta (from 7 August) to FKa on 26 September https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-1x/support#support-dl-bios.
One day after Thomas_Hannaford's announcement.
And no mention at all of the 0x12B microcode.
And still no answer.
JedG_Intel
Hi AMR41,
Based on your manufacturers site, I can see that they introduced the microcode 0x12B on the recent BIOS version FKa last September 26,2024 here. Please contact your board manufacturer for more information and assistance in case you will update your BIOS.
Have a good one!
Jed G.
AMR41
Thanks JedG.
Yes, I saw on the 26th that they had changed the beta to FKa, but nothing about the 0x12B update.
It was the next day when they changed the text in the description and it appears:
3.Introduction of the 0x12B microcode as a final mitigation for the 13th/14th generation desktop processor Vmin switching instability issue according to Intel official.
  i. 0x12B includes microcode updates 0x125 and 0x129 and addresses high processor voltage demands during periods of idle and/or           low activity.
  ii. microcode 0x129 (August 2024) addresses high voltages requested by the processor.
  iii. microcode 0x125 (June 2024) addresses the eTVB algorithm issue.
I've asked when the Beta FKa update will become normal, but I haven't heard back yet.
I'll keep waiting a few more days....
The PC is still running normally, but like a 10th or 9th generation i7.
Hopefully with the new update I will get the processor behaviour back to its original mode.
Kind regards.
JedG_Intel
Hi AMR41,
Since your board manufacturer already introduced the microcode 0x12B, please continue communicating with the OEM moving forward so they can address your concerns about their implementations of the said update.
Have a good one!
Jed G.
AMR41
Okay Jed.
I'll keep waiting to see what Gigabyte tells me about when they'll switch the Beta FKa update to normal.
And while this is happening, a reminder about the fundamental question of this post that I made on 08-23-2024
What happened to the queries to Intel, about an application or an update of XTU that would allow me to act as I do from Windows with the “Processor Performance Enhancement Mode”?
Greetings
JedG_Intel
Hello AMR41,
About your original inquiry regarding the update on XTU, I have forwarded the feedback to the relevant team and they'll be the one to check and validate if we can incorporate your ideas to future updates. Rest assured that your feedback will be considered.
After providing you assistance, I can say that all concerns have been addressed. Having said this, I will now close this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
