Processors
14513 Discussions
WHEA-Logger Event ID 17
56Kruiser
On my HP Envy 360 several times a day I am getting WHEA-Logger Event ID 17 errors. General info says:
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Bus:Device:Function: 0x0:0x1C:0x0
Vendor ID:Device ID: 0x8086:0x9D13
Class Code: 0x30400
I have checked and updated all drivers from HP, as well as Intel. I called HP, and they said it needed to come in for warranty repair. All they did was update it to Windows 1809, and run diags. It passes all Diags, which I told them when I sent it in.
I have run Windows verifier on all the drivers for 36 hours and get no BSODs.
Any suggestions?
Wanner_G_Intel
Hello 56Kruiser, This issue can be caused by outdated drivers, BIOS, or 3rd party software. To resolve this issue, we recommend checking the following information: A. Make sure the chipset driver is up to date. B. Load default BIOS values. C. Make sure you are running the latest BIOS. We recommend contacting your system manufacturer in case you need to update BIOS. D. Is your system running within specifications? (No overclokcing; Undervolting) Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
56Kruiser
I have updated all drivers from HP site; 3 that weren't listed on HP site, but is on Intel site: Have updated bios, all set to default; system is stock, no overclocking or undervolting.
I had sent the unit to HP to repair. All they did was install latest version of Windows 1809.
No communication about the problem reason I sent it.
Error continues.
A guess a bigger concern for me: Given that it says "A corrected hardware erroro has occurtd"...do I have a problem with the hardware or not? I find it interesting that it is corrected.
If there is a hardware problem, I definitely want to get it fixed while on warranty. That siad, I sent it in while on warranty, but warranty stopped a few days ago. But I think I could resend it based on it having been in on this problem already.
Wanner_G_Intel
Hello 56Kruiser, These error messages may be caused by operating system updates, drivers or 3rd party applications. If your system shows error messages even after installing the drivers customized for your system, we recommend contacting your system manufacturer for warranty options and support. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
56Kruiser
Thanks for the reply, Wanner.
This is interesting...as it is confusing when it indicates a "corrected hardware error". Make me think there is a hardware issue.
Working with HP is useless. I had actually sent it in on warranty, and they sent it back after just wiping and installing v1809 of Windows. When I got it back I had to install updated drivers, and Windows updates, none of which stopped the error.
I guess all I can do is live with it. I"m more comfortable if it in tact is not really a hardware error. I wanted it to be fixed if that was the case. It does pass all of HP's diags.
Wanner_G_Intel
Hello 56Kruiser, Receiving these error messages usually does not mean that a component is faulty. Most of the times they suggest that there are driver/OS or system conflicts. Even though you are running the latest Windows* build (RS5), we recommend checking Windows* Updates, scan and apply all of them if available. You can also go into Windows* Device Manager and look for error codes. If applying the latest driver/OS updates does not alleviate this problem, you can also perform a clean boot. In that way, you can determine if 3rd party applications are causing these issues. How to perform a clean boot in Windows https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there. I hope you find this information helpful. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
56Kruiser
Latest...
I've been checking 2-3 times a day for any updates from Windows Update, HP Support Assistant, and Intel'd Driver utility. I also did browse the Device Device Manager, found nothing with !.
Yesterday when I did a Windows Update, it did install January 22, 2019—KB4476976 (OS Build 17763.292),
This morning when I got up the computer had apparently booted from sleep during the night, was at a dark screen that would not come on. A click of the power button turned the unit off immediately. Below are results:
I have no idea if you folks interest in looking at dmp files or not. But I'll put a Dropbox link here in case you do:
Link to Memory.dmp-> https://www.dropbox.com/s/iof9pfykbdtsern/MEMORY.zip?dl=0
Link to Logger files from a utility on TenForums-> https://www.dropbox.com/s/nlb4d5y3e33r8ik/ROGERSLAPTOP-%282019-01-26_08-43-30%29.zip?dl=0
These were the drivers seen in the latest BSOD:
Bugcheck code 0000009F
Debug session time: Fri Jan 25 22:25:15.575 2019 (UTC - 6:00)
igdkmd64.sys Wed Apr 25 19:08:56 2018 (5AE11898)
iaStorAC.sys Mon Dec 3 15:21:08 2018 (5C059E44)
IntcDAud.sys Fri Apr 6 11:12:58 2018 (5AC79C8A)
ibtusb.sys Wed Nov 21 04:15:22 2018 (5BF5303A)
Some of the code in those files:
ibtusb.sys Intel(R) Wireless Bluetooth(R) Filter Driver https://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr     IntcDAud.sys Intel Graphics Media Accelerator HD Driver http://downloadcenter.intel.com/     iastorac.sys Intel RST (Rapid Storage Technology) driver OEM or http://downloadcenter.intel.com/Default.aspx     igdkmd64.sys Intel Graphics driver http://downloadcenter.intel.com/Default.aspxName Intel(R) UHD Graphics 620 PNP Device ID PCI\VEN_8086&DEV_5917&SUBSYS_8420103C&REV_07\3&11583659&1&10 Adapter Type Intel(R) UHD Graphics Family, Intel Corporation compatible Adapter Description Intel(R) UHD Graphics 620 Adapter RAM 1.00 GB (1,073,741,824 bytes) Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\ki127756.inf_amd64_cd9f19051b5853c8\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki127756.inf_amd64_cd9f19051b5853c8\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki127756.inf_amd64_cd9f19051b5853c8\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki127756.inf_amd64_cd9f19051b5853c8\igd12umd64.dll Driver Version 24.20.100.6025 INF File oem43.inf (iKBLD_w10_DS section) Color Planes Not Available Color Table Entries 4294967296 Resolution 1920 x 1080 x 60 hertz Bits/Pixel 32 Memory Address 0xB0000000-0xB0FFFFFF Memory Address 0xA0000000-0xAFFFFFFF I/O Port 0x00003000-0x0000303F IRQ Channel IRQ 4294967289 Driver c:\windows\system32\driverstore\filerepository\ki127756.inf_amd64_cd9f19051b5853c8\igdkmd64.sys (24.20.100.6025, 12.51 MB (13,121,000 bytes), 5/8/2018 3:35 PM)Name Intel(R) 6th Generation Core Processor Family Platform I/O SATA AHCI Controller Manufacturer Intel Corporation Status OK PNP Device ID PCI\VEN_8086&DEV_9D03&SUBSYS_8420103C&REV_21\3&11583659&1&B8 Memory Address 0xB1230000-0xB1231FFF Memory Address 0xB1239000-0xB12390FF I/O Port 0x00003080-0x00003087 I/O Port 0x00003088-0x0000308B I/O Port 0x00003060-0x0000307F Memory Address 0xB1237000-0xB12377FF IRQ Channel IRQ 4294967292 Driver c:\windows\system32\drivers\iastorac.sys (16.8.0.1000, 1.04 MB (1,094,792 bytes), 12/6/2018 4:48 PM)iastorac Intel(R) Chipset SATA/PCIe RST Premium Controller c:\windows\system32\drivers\iastorac.sys Kernel Driver Yes Boot Running OK Normal No YesName Intel(R) Display Audio Manufacturer Intel(R) Corporation Status OK PNP Device ID INTELAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000\4&4D59C32&0&0201 Driver c:\windows\system32\drivers\intcdaud.sys (10.25.0.5, 611.02 KB (625,688 bytes), 4/25/2018 2:23 PM)intcdaud Intel(R) Display Audio c:\windows\system32\drivers\intcdaud.sys Kernel Driver No Manual Stopped OK Normal No Noibtusb Intel(R) Wireless Bluetooth(R) c:\windows\system32\drivers\ibtusb.sys Kernel Driver No Manual Stopped OK Normal No NoLog Name: System Source: Microsoft-Windows-WHEA-Logger Date: 2019-01-25T23:23:16.588 Event ID: 17 Task: N/A Level: Warning Opcode: Info Keyword: N/A User: S-1-5-19 User Name: NT AUTHORITY\LOCAL SERVICE Computer: RogersLaptop Description: A corrected hardware error has occurred.   Component: PCI Express Root Port Error Source: Advanced Error Reporting (PCI Express)   Bus:Device:Function: 0x0:0x1C:0x0 Vendor ID:Device ID: 0x8086:0x9D13 Class Code: 0x30400   The details view of this entry contains further information.
The fellow at TenForums said I should completely do a refresshed Windows install (which HP did last week), and not install any programs and run it for 2 weeks and see if it happens.
I'm about ready to call HP again, but I"m not hopeful they will be any help.
