Processors
14536 Discussions
WHEA-Logger Event "A corrected hardware error has occurred" 8700k is faulty?
SLitw
Hi. Today i checked my event viewer and found some weird errors in 21.01.2018 :
System Warning 21/01/2018
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: 1
Error Type: 9
Processor ID: 0
I have to remark that besides the event monitor logs there are no other symptoms of malfunctioning processor - it works like a charm. I'm just concerned if these corrected errors won't become critical errors in the future and I want to know the nature of them - maybe I have a buggy system or something?
Its only in 21.01.2018 day. I remember that system was idle in night this time.
Ok my pc:
8700K stock, MTU on, 4700mhz auto
Asus Z370 Pro Gaming
16GB DDR 3000MHZ ( XMP )
Corsair 750i
SSD Crucial 525GB
HDD TOSHIBA 500GB
Windows 10 clean install 1709 Creator Fall Update
Temps of cpu fine,temps of gpu fine. Never had any single BSOD. Memtest86 no errors. All benchmarks passing, no crashing in games
. Only saw that error in event viewer which make think that is still with cpu or what?
Allan_J_Intel1
Hi frusciante23,
I understand you are getting WHEA-Logger in the Event Viewer, let me help you on this matter.
The central processing unit detects hardware problem. Hard to say unless you start swapping parts.
Please check the following link from Microsoft* that explains about this message: https://social.technet.microsoft.com/wiki/contents/articles/3567.event-id-18-microsoft-windows-whea-logger.aspx https://social.technet.microsoft.com/wiki/contents/articles/3567.event-id-18-microsoft-windows-whea-logger.aspx and follow recommended actions.
In case you need more assistance or if you have any questions do not hesitate to contact us back.
Allan J.
SLitw
Errors starts showing on IDLE in event logs in 3 a.m and finished at 3 at noon. After that errors stops showing.
I triied memtest86,ihcmemtet all benchmarks and no errors. No bsods,no freezing.
Any ideas why that happened? That was error related to hardware or ?
SLitw
HEY UPDATE !
I checked now events today. And it stopped throwing that errors after installing update on 22.01 :
https://support.microsoft.com/pl-pl/help/4056892/windows-10-update-kb4056892 https://support.microsoft.com/pl-pl/help/4056892/windows-10-update-kb4056892
KB4056892 (kompilacja systemu operacyjnego: 16299.192)
SLitw
This update is from 3.january.:
So why on previous Win10 build was throwing errors, propably it was 16299.15 . I dont remember which build of Win10 was first after installation,because soon later W10 was updated to 16299.192
Still i have something wrong with hardware?
Hi frusciante23,
Thank you for the updates.
If you are not getting any errors so far, this could be the operating system itself. I recommend keep testing your hardware.
If this is a hardware issue, I recommend contacting Intel for warranty service and choose processor area: https://www.intel.com/content/www/us/en/support/contact-support.html https://www.intel.com/content/www/us/en/support/contact-support.html
Allan J
SLitw
This day i remember i finished installing Windows 10 with 16299.15 build ( build before meltdown/spectre ). And system was completely on idle overnight.
I remember that after windows 10 updated to build 16299.192 . + disabled hibernating errors stop showing. After that errors stops showing. After update 0 errors. Then i updated to 16299.214 newest and still 0 errors.
Can somebody tell me if my hardware is fine or not? It was throwing WHEA-ERRORS on build 16299.15
