My PC randomly hang. What is the issue. Driver? Hardware?
Also, sometimes, when it hang, there is one pixel wide vertical red line on the left of the monitor from top to bottom.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffe001b34f0028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000ba000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000058000402, Low order 32-bits of the MCi_STATUS value.
SYSTEM_PRODUCT_NAME: Aspire V3-572G
BUGCHECK_P1: 0
BUGCHECK_P2: ffffe001b34f0028
BUGCHECK_P3: ba000000
BUGCHECK_P4: 58000402
BUGCHECK_STR: 0x124_GenuineIntel
STACK_TEXT:
ffffd001`39c49cf8 fffff803`cb5cc213 : 00000000`00000124 00000000`00000000 ffffe001`b34f0028 00000000`ba000000 : nt!KeBugCheckEx
ffffd001`39c49d00 fffff803`cafc6cf1 : 00000000`00000001 ffffe001`b0d0d2f0 ffffe001`b0d0d2f0 ffffe001`b34f0028 : hal!HalBugCheckSystem+0xcf
ffffd001`39c49d40 fffff803`cb5cc6a0 : 00000000`00000728 00000000`00000002 ffffd001`39c4a130 00000000`00000000 : nt!WheaReportHwError+0x22d
ffffd001`39c49da0 fffff803`cb5cca0d : ffffe001`00000010 ffffe001`b0d0d2f0 ffffd001`39c49f48 ffffe001`b0d0d2f0 : hal!HalpMcaReportError+0x50
ffffd001`39c49ef0 fffff803`cb5cc8f8 : ffffe001`b0d0cc80 00000000`00000001 00000000`00000002 00000000`00000000 : hal!HalpMceHandlerCore+0xe1
ffffd001`39c49f40 fffff803`cb5ccb42 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xe4
ffffd001`39c49f80 fffff803`cb5ccccf : ffffe001`b0d0cc80 ffffd001`39c4a1b0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xce
ffffd001`39c49fb0 fffff803`caf61dbb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
ffffd001`39c49fe0 fffff803`caf61b71 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7b
ffffd001`39c4a120 fffff803`cb5b082f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x171
ffffd001`39c698e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalProcessorIdle+0xf
I would like to note that I've run Intel Processor Diagnostic Tool 64 bit and found no problem.
Hi Fablefox,
In regards to this WHEA issue you are getting, we haven't seen it before on 4th generation processors.
The workaround for this issue on 6th generation processors was a BIOS update, I recommend you to try with that, if the issue comes up or continues; contact Acer* and report this issue:
http://www.acer.com/ac/en/US/content/support-product/5389;-;Aspire%20V3-572G http://www.acer.com/ac/en/US/content/support-product/5389;-;Aspire%20V3-572G
Hellen.
