Processors
15857 Discussions
WIFI Driver Intel(R) Wireless-N 7260- unable to connect to Wi-Fi
ragas
Hi ,
I see my wifi is not working and these are the details of my wifi driver which are currently installed in my Dell laptop Windows 10.
Can you please help me to get the download link for connecting to the wifi driver, So that i can install and use.
Windows 10 Home,version 22h2
my driver is Driver : Intel(R) Wireless-N 7260
Interface name: Wi-Fi
Vendor : Intel Corporation
Provider : Intel
Date : 8/23/2015
Version : 18.20.0.9
INF file : oem84.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Vendor defined Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
n_scott_pearson
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my discontinued adapter driver archive. Subfolders provide the final driver packages supporting most of the Discontinued Wireless adapters.
Hope this helps,
RAAK
Scott, thank you very much for the driver files.
1st I thought my N 7260 was bad and ready to order. My laptop sees my neighbors wifi, but my wifi.
Run troubleshooting and results no issue.
So decided to look for driver in Google and ended here.
ragas
Thanks for the help I see now the wifi is working but have small query on the drivers, I have downloaded (WiFi 21.10.1 64 Win10) file and installed from the link but when I see the adapter settings it shows up be a different version from the one which you provided. Can you please help me with that.
my current wireless driver settings ...from cmd
Provider : Intel
Date : 10/14/2013
Version : 16.6.0.8
INF file : oem140.inf
n_scott_pearson
My initial reaction was that you were seeing the first entry in the list of available driver versions on your PC. To be sure, you need to display the driver version number that appears in Device Manager.
If you do not see driver version 18.33.17.1, then you are going to have to do a full-and-proper clean install. Here is a step-by-step process:
  1. If you haven't already, download to your PC - but do not install just yet - the 21.10.1 Bluetooth and Wireless driver packages.
  2. Most important! Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable. Note this Wireless disable *must* be of type that will persist (stay disabled) across reboots.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Dual Band Wireless-N 7260 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go forward to Step 10.
  7. Right click on the entry for Intel Dual Band Wireless-N 7260 and uninstall it, choosing (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go back to Step 5.
  10. Install the downloaded Bluetooth driver package (my rule: always install Bluetooth first).
  11. Install the downloaded Wireless driver package.
  12. Manually shutdown and reboot your computer.
  13. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  14. Test.
Note that it sometimes takes multiple uninstalls (and reboots) to clean out the old installations, so don't give up on the process until you hit, say, 10 reboots.
Hope this helps,
RAAK
Scott, thank you very much for excellent instructions.
I followed and fixed the issue in one rebooting.
RAAK
Ragas, thanks for your posting, I had same issue and now it fixed.
