Processors
14493 Discussions
What graphics card is Intel's Integrated Graphics equivalent to?
NavN
Reason for asking:
I purchased a new 550W SMPS to check if a PSU failure was the reason my 11 year old PC wasn't booting. Still no boot, so I'm purchasing a new processor (Intel i5 11400), motherboard and RAM. However, since the 11400 works at 154W in PL2, and I'd likely have to run it in turbo mode and with XMP enabled, for many hours at a stretch, (and due to a low budget), I may not be able to add a dedicated graphics card, because of the SMPS's 550W limitation and the amount of heat generated by the CPU (for which I'd have to buy an after-market cooler).
Background info:
This is not for gaming, but I will be programming Convolutional Neural Networks, Generative Adversarial Networks (for which a GPU is helpful) and maybe develop some very simple 3D games using Unity 3D or Godot Engine.
The question:
So I'd like to know approximately (I know you can't be exact, but you can certainly make a ballpark estimate) what NVIDIA graphics card the i5 11400's Integrated Graphics is almost equal to. I'll be using 16+16GB DDR4 3200MHz RAM and either an MSI or ASUS B560 motherboard. As a response, you could reply something like: "The i5 11400 can give you the approximate performance of an NVIDIA GT 710 graphics card".
AlHill
The answer for that will not be found here.
So, you can do some research yourself.
This is your processor:
https://ark.intel.com/content/www/us/en/ark/products/212270/intel-core-i511400-processor-12m-cache-up-to-4-40-ghz.html
It has Intel® UHD Graphics 730
With that information, you can look for sites that do comparisions.  Here is one for example:
https://gpu.userbenchmark.com/Compare/Nvidia-GeForce-GT-730-vs-Intel-UHD-Graphics-730/m12582vsm1500304
Here is another.  As you can see, the intel graphics rate pretty low:
https://www.videocardbenchmark.net/gpu.php?gpu=Intel+UHD+Graphics+730&id=4379
So, good luck with your research.
NavN
Thank you. That's exactly what I wanted to know. So I need a separate graphics card only if my requirement goes above a GT 730's capability.
